Results 1 to 10 of 10
Thread: Not sure what my results mean - do I need to shock?
    May 2012
    SW Georgia
    Default Not sure what my results mean - do I need to shock?
    Hope someone can help me. I have just tested my water (using Taylor K206) results as follows:
    FC 13ppm
    CC 0.6
    PH 7.2
    CYA 110
    CH 260 ( I know this is low)
    Do I need to shock?
    Thanks very much :-)
    in-ground gunite pool 20x40; Sta-Rite Dura Glas pump; sand filter
    May 2013
    Northwest Indiana
    Default Re: Not sure what my results mean - do I need to shock?
    Your cya is very high... The test is inaccurate over 100ppm so yours could actually be higher. I would suggest retesting cya with half pool water and half tap water then double your result. Use the "best guess" chart here. Also, use the 10ml sample method when testing for fc and cc to save on reagents. If you have over .5 ppm cc, then you should shock.
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
    May 2012
    SW Georgia
    Quote Originally Posted by Themadczar View Post
    Thank you I will do that tomorrow as it is now dark. Am new to using the test kit so am a little wary as to whether I did the CYA test correctly. Thanks again for your response :-)
    May 2013
    Northwest Indiana
    The cya test is tricky to read correctly. You want bright, indirect light. So ideally stand in sunlight with your back to the sun (your shadow directly in front of you) and view the dot in the comparator by holding it at your waist. You can also pour the sample back into the bottle and retest a second or third time to verify your results.
    May 2013
    Northwest Indiana
    Forgot to ask... What are you using to chlorinate?
    May 2012
    SW Georgia
    I have to admit I have been using pucks in the chlorinator as I wanted to use them up. I no longer have any left so it is back to bleach for me. I have followed the instructions given and retested the CYA this morning results as follows:
    CYA 90
    FC 15
    CC - this is where I got stuck interpreting the reading. When added the 5 drops the water turned pale pink, added 2 drops of the other (sorry haven't got number of bottle handy) and the water turned clear again.
    May 2013
    Northwest Indiana
    Ok, just so we are clear... 90 is the cya level after doubling the actual results? And for the cc, are you using a 10ml sample? If so, and it took 2 drops to clear the water then your cc is 1ppm and you need to shock (which is either 20 or 25ppm fc depending on whether your cya is 90 or 180.)
    May 2012
    SW Georgia
    Yes, CYA is 90 after doubling. I don't know what the heck I did yesterday when testing CYA! Your instructions were spot on and helped me immensely.
    I thought the CC was 1 but wasn't sure, and yes I was using a 10ml sample.
    Thank you so very much for helping me I really appreciate it!
    May 2013
    Northwest Indiana
    No problem. You also want to make sure you leave the pool uncovered as much as possible when the sun is on it... Sunlight and outgassing will help keep cc in check.
