Thread: Vinyl liner loosing water
    Default Re: Vinyl liner loosing water
    Not sure I know what is happening. When you use the dye, do you turn off the pump and let the water go very, very still? The dye should collect at leak points. Last summer I was checking one leak and the dye collected on the floor and indicated another pinhole leak I was TOTALLY unaware of, now fixed.
    May 2011
    Southeast Massachusetts
    Don't mean to hijack the thread but can you tell me more about the dye method. My water level has gone down about 2-3 feet since closing. This happened before and I refilled upon opening with no abnormal loss during the following season so chalked it up to evaporation (which doesn't tabulate with me given the winter cover is on but...)
    Anyways...I'll refill upon opening again but should do a dye test to find any pinhole or large leaks. Can you tell me more about the dye. Does it fade or how do you remove it after the test is concluded. Admins...feel free to repost in a new thread. Thanks.
    15,000 Gallon AG -24' round -- Vinyl Liner -- 1 HP Hayward Power Flow LX -- Sand Filter -- PF=5.5
    East coast
    I think the plastic ring that seals the liner to the fitting in the bottom is my problem. I have ordered a new one. Im not sure if I can get the liner to match up exactly where it was to install it?
    38000 Vinyl IGP filled w/ well H20, SWCG-CI40, DE Filter, Elec. heat Pump
    24x40 rectangle 36K gal IG pool; SWCG; Pentair DEQuad DE filter; Hayward pump; 12hrs; ColorQ Pro by Lamotte; well; summer: ; winter: ; iPhone; PF:3.3
    AFAIK, the dye is harmless. You want the water VERY still so the dye will collect at the leak and you should have an idea where the leak is. But once it's fixed, and the water's moving, you won't see the dye.
