Results 1 to 10 of 34
Thread: 20k gal pool in Sol Cal. .....needs to be drained.
    Apr 2014
    San Diego, CA
    Default Re: 20k gal pool in Sol Cal. .....needs to be drained.
    I told the wife to CAN IT. There are bigger fish to fry around the house than a pretty color pool.
    But it's that bad to get a dark pool? I suppose that is why the light blue is so popular. We took a hot air baloon ride several years ago, and went over Rancho Santa Fe ($2-20M homes) and saw several dark blue pools. But not close enuf to see any discoloration. What's that phrase, "once you go dark you don't go back?"
    Thanks for the tip though. What causes the discoloration? Chemicals, I would guess.
    plaster 20k gal kidney shaped swimming pool with spa Hayward Vac, Nautilus DE filter, Raypak RP2100 gas heater.
    Quote Originally Posted by pmaru77 View Post
    Think maybe you're confusing "pools" with something else. Dark pools are a headache in most cases, but they look cool even though they usually get too hot in the summer sun.
    Nope. Plaster and dye qualities, plus installation technique. Some of the same 'streaking' occurs with white plaster, but you don't see it without the added dye.
    Apr 2014
    San Diego, CA
    OK, the pool was completely drained and it took 24 units of city water to fill the pool and spa. So far I have added 1 and 1/2 gallons of liquid chlorine and about 1/3 gallon of muratic acid. I also have the floater loaded with a few pucks. I'm using the pucks to get chlorine and more importantly the triclor so th CYA will come up to something readable. I have checked the pH before adding the muratic acid, and the pH was high, but it only took a few drops of #3 to get the test ok. That is by far the best I've had (easiest) since testing prior to the refill. So as it stands now, the chlorine is aok right now, and I think the pH is ok, but need to test after things settle down. So the plan is to monitor the chlorine and pH levels twice daily...in the am and in the pm. I figured I would wait and see how things go before I thest the CYA, becasue I assume there is none to speak of except what comes out of the pucks in the floater.
    I have in stock, liquid chlorine, liquid muratic acid, tricoloro-s-.... pucks.
    So what other tests should I do at this time that would be of use?
    Apr 2014
    San Diego, CA
    UPDATE:
    I am a subscriber now. ($14)
    I decided to run some more tests. K-2006 test kit
    TA 15 x 4 = 60
    CH 20 to 25 drops x 10 = 200-250
    pH 7.9
    FC 6 drops x 3 = 1.8 ppm ?
    CC nothing
    CYA nothing as expected
    I'm on day 1 of pool refill.
    How many days do I have to get things right before having trouble? No pool useage until May 1st.
    Already getting nervous about no CYA. Should I go get product? and what? (HD or LOWES) and not Leslies.
    At this point, if you dump 1/2 gallon of bleach in the pool nightly, you'll be fine. Do it late though: the sun will strip the chlorine quickly!
    Also, start adding acid AND baking soda. You need higher TA (or really, carbonate alkalinity) since you have a plaster pool, and a pH that's at least a little lower. Read the muriatic acid page, linked in my signature block. MA is better for your pool, and cheaper, but the fumes are BAD!
    Do you have access to a Sams Club? If you do, see if they have the PoolBrand dichlor or trichlor there. Meanwhile, get a floater (Walmart!) and start using your tabs. Tabs are very acidic, so don't push your pH below 7.6.
    Apr 2014
    San Diego, CA
    I have HD liquid chlorine a $7 per 2 gallons. If I use 1/2 gallon a day, that is $100 month. Where am I wrong here? Is regular bleach cheaper?
    Or is the daily chlorine temporary?
