Results 1 to 10 of 28
Thread: Replacing cartridge with sand
    BigDave's Avatar
    Default Re: Replacing cartridge with sand
    Earlier you said that the "pool isn't all that clean" is the reason you are considering filter change. I thought that meant water quality (to me: little tiny stuff in water that makes it look dull). Did you mean something else by clean?
    No thanks needed (but appreciated), I like to help.
    And, Dave, we appreciate all the help you do give! Thanks!
    BigDave's Avatar
    Right back at you Lisa.
    May 2013
    Concord,ca
    what I meant was sometimes the filters seem like they don't do enough to keep the pool free from debris. The sweep works fine. Thanks, Dave
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    You could either have inferior brand cartridges, you are not cleaning them correctly, or your cart is too small for your pump.
    A properly sized cartridge filter, properly maintained, should perform better than a sand filter but not as well as a DE filter.
    Most people here don't like them because they are tricking to clean, but those who figure out how to clean them well, and with little effort, swear by them.
    May 2013
    Concord,ca
    I have decent cartridges but I need to find a better way to clean them. I saw a device where you lay the filter down in a tray and run the spray nozzle over them, plus I may need to get rid of a couple. How long are they supposed to last if cleaned twice a year? Thanks to all Dave
    BigDave's Avatar
    Have you seen PoolDoc's thread on Cleaning your Cartridge Filter without Damaging It!?
    Largo, Florida
    Quote Originally Posted by dansdad View Post
    Twice a year? I clean my cartridge weekly during the summer and fall. Twice a week in the spring. Once a month (roughly) in the winter.
    I've never had a cartridge get ruined but after about a year the "clean" filter pressure ends up about 10psi higher than the "clean" pressure was when I bought it. I replace mine roughly every 18-24 months.
