Closed Thread
Results 1 to 10 of 22
Thread: Should I Get a UV unit for My Pool
    May 2014
    Plano, TX
    Default Re: First Pool Ever
    If the pool is not covered, you'll get plenty of UV from the sun. It seems the general consensus around here is that the CORRECT UV system MIGHT be helpful for an indoor pool, but is probably a waste of money for an outdoor pool. Be sure to read everything at PoolSolutions.com. It is a sister site. You'll also want a good test kit so you'll know what condition your pool water is in. http://pool9.net/tk/
    Enjoy your new pool & WELCOME to the Pool Forum. It's a great place to learn about how your pool should be cared for.
    Pappy
    Jun 2014
    SE Michigan
    Pool Doc and Pappy, thanks for the information. We won't take possession of the new place until July so I'll get back with the details you asked for. Speaking with the seller, he seems to have a pretty good maintenance plan for his pool that I asked him to write down for me. I'm not gonna lie, it's intimidating for a new owner. I will have a hundred questions like how long to run the filter (I think he said he runs it 8 hours a day), etc. I'm reading as much as I have time for on these forums. Thanks again.
    PS: I ordered the test kit recommended here. And the current owner has those inflatable solar rings floating on about 3/4 of the surface.
    Jun 2014
    SE Michigan
    OK, we are still 2 weeks away from closing and taking over the new house and pool. But we went over today and I brought back a water sample to test with my new K2006 kit. I don't know the water temp but the ambient temp was around 82 and I would say with all-day sun the water temp was at least upper 70s. It looked clean and pretty clear. I could see the Polaris 280 in the deep end (8 feet) pretty clearly. I also noticed it has a Hayward Chlorinator (not inline) and the homeowner uses trichlor tablets in the chlorinator. Here are the test numbers:
    pH 7.4
    CYA 85
    CH 270
    FC 13.5
    CC .5
    TA 100
    I believe he runs the filter 8-10 hours each day and that's about all I know. What do you think?
    32k free-form, Triton II TR-60 sand filter, Sta-Rite 1 hp pump, BBB, Polaris 280 cleaner, Jandy Zodiac heater, K-2006
    Those numbers are fine -- no reason to panic or even stress.
    Basically, you could get by for weeks just by pouring 1/2 - 1 gallon jug of bleach into the pool every evening. So, now you have a super simple fall-back plan.
    Jun 2014
    SE Michigan
    Good to know. Thanks, I appreciate the information.
    Jun 2014
    SE Michigan
    Things are happening and they look bad. My closing on the new house and pool has been delayed until later next week. The owner has moved out and left the pool care to the neighbor, who only turns the pool filter on in the am and off at night. We stopped over to look around this evening and the water looks a little cloudy and there is definitely something on the bottom and walls. Worse still, the water level is getting low near the top of the skimmers with no real rain in sight. And worse still, the house is on a well so no filling from the house. I managed to find a small porcelain pot to bring some water home to test as best I can. I got a CYA well over 100, FC of 36, CC of 1 and pH of 7.2. I wonder if he threw in a bunch of trichlor before leaving town (he uses it in the chlorinator) because there was some algae or something. I feel like I should do something to fix this so it doesn't become a much bigger problem before I ever get a chance to move in. My first move will be to buy some water to bring the level up. I could use some advice on what to do after that. I need some help, please.
    Order a K2006 ASAP => http://pool9.net/tk
    Do a full bucket leak test, ASAP. If you have no means to fill the pool, and you have a leak . . . you have an unmanageable situation. How did he fill the pool? => www.poolforum.com/pf2/showthread.php/11252
    Nov 2018
    Texas
    Quote Originally Posted by Pappy View Post
    FWIW, according to the American Cancer Society, the UV we get from the sun is 95% UVA and 5% UVB. UVA and even moreso UVB can cause skin cancer, but are only moderately effective at killing bacteria and viruses. UVC, the UV that is used for disinfecting, aka "germicidal UV" is a different part of the light spectrum--approximately 254nm. UVC is the UV used in water treatment. UVC does not penetrate the atmosphere, even at the equator, so you don't get the "good UV" from sunlight (although there is some indication that some UVC might be getting through at the south pole.) So UVC is man made down here at the earth's surface.
    The combination of UV and ozone are claimed to eliminate chlorine compounds. In my tests, "CC" is always -0-. There is also evidence that chlorine-resistant bacteria and parasites are killed by O3 and UV systems. For some people the evidence is sufficient to use O3 and UV in addition to chlorine. I won't start an argument for or against, as from what I've read here and elsewhere, the Yes/No for O3+UV seems comparable to the Yes or No, For or Against the value of a manual thumb safety on a defensive handgun. Those opposed will not be swayed in their beliefs, nor will those for. Luckily both groups can have it their way, as it is a preference, not a law.
    When considered in the context of the entire cost of a swimming pool and spa, the addition of O3 and UV treatment is not much money. Like I said, FWIW.
    Hope everyone had a happy Thanksgiving and has a Merry Christmas.
    Bill
    We've been over this at least a dozen times in the forum. While some of your statements, like "There is also evidence that chlorine-resistant bacteria and parasites are killed by O3 and UV systems" are true theoretically, they are not true practically with respect to any system you are likely to install on your pool. (Well, unless you are willing to spend several $100,000's for a German DIN-standard ozone system, plus several $100,000's MORE, per YEAR, for a team of German system operators living on site.)
    I'm not wasting my time analyzing the specific details of the expensive junk you've been sold, just to prove, all over again, that the systems actually sold are useless or worse. And, I'm not going to allow you to waste other people's time, misleading them as you attempt to justify your purchase decision. I've tried to be nice about such stuff in the past, but it doesn't work.
    If you want to convince yourself that you haven't been snookered, feel free to do so in the privacy of your own home!
    But, I'm not going to allow it here. Please go argue your point elsewhere.
    PS. If this is what you meant by the 'other forum' being "close-minded", well, please consider me and the PoolForum close-minded, too.
Closed Thread
