Re: oxidizer shock
Cya is between 70 and 80. Cya has been as low as 50 and after shocking pool water would eventually turn green. I have done the "maintain shock level for 24 hours" methid then maintianing free chlrine 6-7 but eventually starts turning green. The algacide has been the only thing that keeps water clear. When I throw in oxidiser it boosts it. So was just wondering about how to measure the chlorine level or the shocking level, if possible. I have the taylor k 2006 . I run filter 6-8 hours. Its a sand filter. Ph, alkalinity, calcium all are in range according to kit test results. Thanks
