Results 1 to 10 of 109
Thread: Salt Water Chlorine Generator for New Pool Build
    Sep 2014
    Tucson, AZ
    Default Re: Salt Water Chlorine Generator for New Pool Build
    Quote Originally Posted by Toybuilder View Post
    SunnyOptimism, can you tell me a little about the EasyTouch? What's good and what you think is bad? We've used the Aqualink RS previously and loved it. Hoping this is similar.
    I have an 8-channel unit (meaning you can program up to 8 circuits with it). I use mine to run the Spa, Pool, High-Speed setting on VS pump, Waterfall pump, lights, etc. It's not fancy and I like it that way. It's a basic 4-line LCD display and it communicates with the IntelliTouch panel by RF link (no Blutetooth, WiFi, etc). So while it may not have all the gizmos and functionality that the more advanced interfaces have (like the ScreenLogic system), I'm very happy with the more solid, low tech approach (and it's water proof so I could drop it in the pool as opposed to my iPad...).
    Downsides - the setup and programming of it is a little arcane but not impossible to understand. So if you're really geeked-out by doing automation and checking your pool parameter via iPhone apps, the EasyTouch is not for you. It has a limited range unless you buy the powered antenna for it (which I have) so if your electronics are far from the house, it won't work without the additional boost from the antenna.
    All-in-all, I really like it and it saves me a trip out to the equipment pad if I want to turn on the pool lights or get the spa running.
    Parker, CO
    Quote Originally Posted by SunnyOptimism View Post
    It sounds a lot like the RS unit we had. I just looked at the bid and it doesn't say how many channels, but since we have more than 4 things to control I'm assuming it's 8. Will have to make sure, though. It also looks like we're getting the wall mounted controller AND the wireless. Will have to confirm that too. Do you happen to know the range of the wireless controller? I just looked thru the brochure and I didn't see anything.
    Sep 2014
    Tucson, AZ
    In attached photo I'm standing at my side door (kitchen) and I'm ~ 40ft or so to the wireless antenna (green circle/blue arrow). The equipment pad is around the corner (red arrow) behind the casita.
    I think my PB said it can do 100ft easy but from inside the house it can get dodgy if you have walls with lots of pipes and wiring.
    Parker, CO
    I don't think we'll need the booster. The wireless controller will only be used when we're outside using the spa, and we'll be well within 100ft. But, good to know the antenna exists. It's not even listed on their brochure.
    Sep 2014
    Tucson, AZ
    Yeah, like the IntelliWand and half a dozen other things that Pentair never tells you about. My PB is a Pentair reseller for this area and he knew all the inside scoop on the various Pentair gizmos. It's not hidden per se, it's just Pentair, like any major manufacturer, wants to steer the consumer as much as possible through their distribution channel. So for the casual buyer, you really have to dig to get the full picture.
    Parker, CO
    Thanks for all your info on the EasyTouch. I feel a bit more at ease with it since it seems similar to the RS. May hit you up again once I get to programming.
    Parker, CO
    Well, I'm checking out until after dinner. You guys are killing me with all this talk about pizzas and hotdogs. Thank goodness dinner will be early tonight.
    Sep 2014
    Tucson, AZ
    Anytime. If the Pool Forum god (aka, @PoolDoc) decides to enable private messaging, then we could take a lot of the incidental questions off the thread. Until then, you'll just have to post. I think my profile allows for vCard access but I'm not sure....
