Results 1 to 10 of 18
Thread: Checking laterals in old Pac-Fab Triton TR60 filter? Sand blowing back into the pool!
    Jul 2014
    Madison, WI
    Default Re: Checking laterals in old Pac-Fab Triton TR60 filter? Sand blowing back into the p
    Would it be wise to re-use the old sand? I'm assuming that the previous homeowners used proper pool sand, as there is a bag of pool sand in our shed. Do I take that risk or spend $50 on new pool sand?
    26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
    Jul 2013
    Northern Illinois
    Wish I could help....
    Quote Originally Posted by mitchryan912 View Post
    The bag of pool sand is probably new. If it looks green, I wouldn't use it. If it looks clean, it's only 50# so you'll need more. I would not reuse pool sand. I suppose it's possible, and, if it's clean, well, as someone pointed out, it's not new but millions of years old...still, if you can get new sand for a reasonable price (on sale for <$10/bag) it's cheap enough to replace it.
    If the old sand is gummed up or full of long green tendrils, abandon it. Period.
    Jul 2014
    Madison, WI
    Thanks for the info. I'm replacing the laterals this morning, and dumping in 50# of new pea gravel, per the Triton manual. Then I'd need 275 lbs of sand on top of that.
    The sand from the bottom of the filter seems pretty clean, and looks just like it does in the bag I have (maybe 15 lbs tops, not a full bag.) It definitely wasn't green. What was on top looked more like a layer of lint from your lint trap in your dryer. The 100# or so I first pulled out has already been dumped.
    Jul 2014
    Madison, WI
    This is what I've got. Does having the gravel mixed in with it make it useless if I don't sift out the gravel first?
    Jul 2014
    Madison, WI
    Bought 250 lbs of new sand a little while ago. Will put in 50 lbs of pea gravel, then the new sand plus what's in the old bag to get me to the 325 lbs it calls for.
    Jul 2014
    Madison, WI
    That's fun. This wasn't supposed to be so difficult... LOL
    Jul 2013
    Northern Illinois
    Is that another crack?
  1. For those of you with sand blowing back into the pool....
    By aylad in forum In-Ground Pool Construction and Repair
    Last Post: 10-24-2015, 08:48 AM
  2. Gravel level with respect to laterals: TR140C Penair Sand Filter
    By RonStordahl in forum Pool Equipment & Operations
    Last Post: 05-30-2014, 09:16 PM
  3. Gravel level with respect to laterals: TR140C Penair Sand Filter
    By RonStordahl in forum In-Ground Pool Construction and Repair
    Last Post: 05-29-2014, 01:28 PM
  4. Pump Blowing Filter Sand In Pool???
    By webfeet in forum Pool Equipment & Operations
    Last Post: 03-27-2007, 12:18 PM
  5. Laterals in Sta-Rite System 3 sand filter
    By Area Man in forum Pool Equipment & Operations
    Last Post: 05-27-2006, 10:00 AM
