What to get when closing with AutoCover ?
1. Can I use this with the water level up in the skimmer ?
http://intheswim.com/Winter-Pool-Clo...mer-Guard-I-G/
2. Can I use these for the outlets ?
http://intheswim.com/Winter-Pool-Clo...er-Pool-Valve/
3. After blowing the lines I would add antifreeze to the return lines and blow until I saw some anti-freeze go in the pool.
4. Do I need to do something else with the skimer ? Last year I copied what the pool guy did. He blew and capped the inlet in the bottom, left the water level up and put a empty chrorine jug in the skimmer .
