Closed Thread
Thread: First Timer closing IG in Charlotte, NC Area
    duraleigh Guest
    Default Re: First Timer closing IG in Charlotte, NC Area
    Hi, Mark,
    Welcome to the South. I live in Raleigh and choose not to close at all......as do the majority of folks around here.
    I turn the pump on when we get freezing temps and that's about it.
    jnorris is offline Registered+ Thread Analyst jnorris 0
    Florence, SC
    Quote Originally Posted by duraleigh View Post
    Hi, Mark,
    Do you leave the pump completely off the rest of the time in the winter? Or do you still run it a little each day? I'm in SC, so we stay warmer than you, and this is our first year with a pool, so I'm wondering what to do. We have a 2 speed pump that I've been running on low 24/7, and turning on high only when we get ready to swim, so the bugs get skimmed off. I'm thinking I want to put it on a timer and have the pump run a few hours in the coldest part of the night, like 3 am to 6 am.
    Judy
    Designated "pool girl" for 16 x 40 IG vinyl pool (installed in 2006) in S.C.
    duraleigh Guest
    Judy,
    Yeah, I still run the pump for normal maintenance and filtering.....greatly reduced because of low chlorine demand and little, if any, use.
    If I had a 2-speed, I'd probably try what you're currently doing (24/7) and see if that doesn't keep it clean. Since I don't, I try to run mine a few hours at least every other day but, generally, I simply eyeball the condition of the water and run it when it looks like it needs it.
Closed Thread
