Results 1 to 9 of 9
Thread: Why is my PB tying to talk me out of 2 speed?
    Jul 2006
    Default Why is my PB tying to talk me out of 2 speed?
    I have printed out info and studied the detail. I just can't see why a 2 speed pump won't be exactly what I need for my pool.
    30k gal 60de filter and 1.5hp pump.
    He tells me the pump's extra cost will not be worth it. He tells me that it won't make that much difference.
    Why? I think I have explained to him why it is advantageous, but he tell me its not worth the extra money.
    Anyone have any help or ideas here?
    Sugar Land, Texas
    Default Re: Why is my PB tying to talk me out of 2 speed?
    Quote Originally Posted by gordonhyde View Post
    Because he's really, really dumb?
    He may not be confident in his or his subcontractor's ability to wire it up and/or program the control system to operate it.
    Pool owner - contract signed 21Aug2006; HOA approval granted; complete - existing patio demolition; excavation; rebar; embedded plumbing; gunite; plumbing; electrical; tile and coping; decking; plaster; pool fill; acid start-up; regular start-up; pool school; gas meter upgrade; additional of salt; PDA remote programming.
    Could be he makes more money off whatever pump he's trying to sell you?
    Get one with a simple idiot switch on the pump housing so he doesn't have to do any special wiring.
    The cost of a 2-speed will pay for itself before you know it. Low speed is quiet, money-saving, efficient and capable of doing everything but vacuuming and backwashing. It can run twice as long and cost 1/3 as much to run that long as the full speed.
    You will NEVER regret installing a 2 speed pump!
    I second the idiot switch on the pump. It works fine and it will be on low 95% of the time. I use high for priming and when the pool opens in the spring. SOOOOO quiet.
    Poughquag, New York, USA.
    My PB talked me out of a 2 speed as well. Now I am putting in one. Stick to your guns. I think PBs are used to doing what they do, one or two pumps, one or two filters, that's it. Much easier for them to order, warehouse, install and service.
    Your PB will probably have to order or find the pump you want - that is more work! The is NO downside to having a 2 speed pump, except the extra 100 or so it will cost, even if you only wire it for single speed now, at least you have the option in the future. Most states are moving towards requiring 2 speed pumps (or variable speed pumps like an Ikeric), your PB might as well get used to it.
    mas985's Avatar
    Pleasanton, CA
    The numbers don't lie.
    Not sure what pump you are considering so I will use a Whisperflow as an example.
    Assumptions:
    1.5 HP Whisperflow full rated 2 speed pump: http://www.poolplaza.com/WhisperFlo-techspecs.shtml
    8.8 amps single speed pump (2.0 kw)
    10 amps high speed two speed pump (2.3 kw)
    3.5 amps low speed two speed pump (0.8 kw)
    60 feet of head loss on high speed
    15 feet of head loss on low speed (1/4 of high speed)
    Results:
    High/Single Speed flow rate = 100 GPM
    Low speed flow rate = 50 GPM
    High/Single Speed turnover = 5 hours
    Low speed turnover = 10 hours
    Assuming 2 turnovers per day and 30 days in the month,
    Single speed energy usage per month = 600 kwh
    High speed energy usage per month = 680 kwh
    Low speed energy usage per month = 480 kwh
    Energy usage difference between single and low speed is 120 kwh per month. Depending on your rates, mine are quite high, this will add up. At $0.20 per kwh, my average rate, this is $24 of savings per month. Assuming a two speed is $200 more than a one speed, the pay off is in less than 9 months. Even if your rates are half of mine, that is still only 18 months.
    Mark
    I have a Hayward 1hp SuperPump 2 speed. I'm not sure of the numbers, but the results are similar. At half the flow it runs twice as long, but that "twice as long" costs half as much.
    Plus, sand filters filter MUCH better when they are running well under capacity. So at low speed your filter will work better (if it's sand-and mine is.).
    Yes to a 2 speed no downside, and if you are in s california edison are offering a $250 REBATE with a controller for a 2 sreed.
  1. If you run a variable-speed pump at half-speed, does the turnover rate double?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-25-2012, 01:22 PM
  2. Dual Speed or a Variable Speed for a plain Jane pool.
    By Lip Out in forum Pool Equipment & Operations
    Last Post: 03-14-2012, 10:32 PM
  3. 2 speed pump. High speed puts sand in pool?
    By mjs31 in forum Pool Equipment & Operations
    Last Post: 08-23-2007, 06:00 PM
  4. Getting ready to dig it up - talk me out of it.
    By Miataguy in forum In-Ground Pool Construction and Repair
    Last Post: 12-10-2006, 08:57 PM
