I'm sure it'll be fine. I'm in the same boat. I believe they are supposed to come by today and fire up the pump and put in some Chlorine.
I'm anxious to get the polaris going to get the leaves off the bottom - can you run a vac on new plaster?
Site owner -- www.troublefreepool.com
Sean, I'm not sure about regular plaster, but the Diamond Brite installation manual includes the following statement:
Do not vacuum the pool with a wheeled vacuum for 14 days, to avoid leaving “wheel marks”. Brush type vacuums may be used immediately.
I would tread carefully, so to speak.
Pool owner - contract signed 21Aug2006; HOA approval granted; complete - existing patio demolition; excavation; rebar; embedded plumbing; gunite; plumbing; electrical; tile and coping; decking; plaster; pool fill; acid start-up; regular start-up; pool school; gas meter upgrade; additional of salt; PDA remote programming.
How long did it take to get plastered? My PB is trying to get the plaster done tomorrow morning. And it looks like it might rain by 11:00..12:00, not sure if that will be an issue?
Geralde,
I agree with Sean's previous entry.
They started the plaster on my pool around 7:00 AM after getting all set up. They did not begin to fill the pool until 1:30-2:00 PM. We had rain scheduled for Sunday early morning. I used water from both sets of neighbors on either end to help me with the fill. My pool was full by 7:30 AM on Sunday (est. 21K gallons). As I mentioned in a previous thread, I would err on the side of caution when it comes to the plaster. Good luck and be sure to upload some pics.![]()
Sean, My PB will not bring the 280 until late next week. I would imagine for the same reason Eljefe was talking about. Do you have a wetsuit? As long as you can get in the pool without stepping on the steps or walking on the bottom, you should be able to clear by hand. I am fortunate that when they built our neighborhood, no trees were left standing. Good luck.
