The 48 oz in 19,200 gallons is equivalent to 25 oz in 10,000 gallons so 2.5 times the example I calculated earlier. So I would expect this PolyQuat to consume 2.5 * 2.2 = 5.5 ppm of chlorine so it is not surprising that it consumed all of your 4 FC. In theory, it would have consumed another 1.5 ppm of the amount you added to shock, though you've said that you didn't notice this when you then added chlorine to shock level, though 1.5 might not be that noticeable when shocking to 13.5 (it's a 10% error).
