Thread: NEC code for Pool Eletrical
    West Palm Beach, FL
    Default Re: NEC code for Pool Eletrical
    Quote Originally Posted by beary View Post
    Hi All
    I would like to install the box in the middle of the wall were the only thing it would be near is the pump and PVC. I would have to step over some of the valves to get to the box.
    Beary
    That is what the code is trying to prevent. You need a clear path to that disconnect, not only for serviceabilty, but safety also. In my area, it does not matter what the equipment is: A/C condensor, pool pump, sprinkler pump, etc., it will fail inspection. Plus the cost of moving box or equipment, the addition cost ot get an inspect back out.....do it right the first time.
    beary is offline Registered+ Thread Analyst beary 0
    Dec 2005
    Quote Originally Posted by Sully View Post
    Thanks, that is what I needed.
    Beary
  1. FAFCO Auto Pool Error Code S2
    By jsnyder2914 in forum Pool Equipment & Operations
    Last Post: 11-25-2012, 10:48 PM
  2. Code Brown!
    By jeepers in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-22-2011, 12:10 PM
  3. National electric code
    By Sean-NJ in forum In-Ground Pool Construction and Repair
    Last Post: 07-28-2006, 10:28 AM
