Results 1 to 9 of 9
Thread: spring start up, general questions, BBB method
    Jacksonville, Florida
    Default Re: spring start up, general questions, BBB method
    first off, thank you all for the replies...
    I just want to make sure that I am doing all I can to ensure crystal clear water throughout the season.
    I saw in a post by Watermom that you add borax then a part of acid, to offset the alk and ph rise. I don't think I need to worry about that, I am today, still sitting right at 7.2, and 80ppm on alk. My FC is 11, TC 11, CYA still 55ppm. So I am not getting a ph swing like I did last year (it always wanted to be at 7.8 or 8.0. I was going thru acid all season last year (first year with it, so I am assuming there was some stabalizing to be done.
    I am running with about 7100 gal of water in my little pool, so I only need to add about 13 oz or so, should I add the acid, or let the ph and alk bump up a notch or so...
    also, can I add this while my TC is high ? (still trying to clear it up the rest of the way, by keeping it up near 15ppm overnight)
    Thanks again for the help!
    ps, without having a borate test in my kit (is it available thru Taylor ?) how do I know what level I am at ? *please dont say take a sample to the pool store... I usually get into an argument with them! **
    Last edited by darenjones; 03-20-2007 at 01:28 PM. Reason: forgot to ask a question, didn't want to make another message
    in the residential and commercial water treatment industry, if you don't have some type of system, get one !!!
    '' common sense aint so common"
    "to be, or not to be... without beer, that is the question"
    Our "easy set" (yeah right, 6 days later) and still working
    but, it is a start to a wonderfull "pool owner lifestyle"
    upgrade is already planned... so don't laugh at it, its our first, and not the last!
    http://pg.photos.yahoo.com/ph/dj71da...?.dir=/562fre2
    As CrisL pointed out, there are TWO different purposes for using Borax. If you add Borax in order to raise pH, then you just add Borax only. If instead you are adding Borax to get to 30-50 ppm Borates for use as an additional pH buffer and an algaecide, then you add a heck-of-a-lot more Borax as well as acid in small portions one after the other (not together). As for how to measure Borates, there are test strips and this is described in more detail somewhere in this thread.
    As for your pH, you could just wait to see how it settles out between the lowering pH effect as the chlorine level drops vs. the increasing pH effect from the outgassing of carbon dioxide. If you see that it drifts upwards on its own, then you can just let it do so as it approaches 7.5 or so. If it doesn't move, then you can add a little Borax to bump it up, but that's really up to you, mostly since 7.5 is a little better on the eyes (but just a little -- the salinity probably has a greater effect in terms of "stinging").
    Exposure to sunlight (if you have any this time of year) is the best way to reduce CCs in your pool. The higher chlorine levels will help, but sometimes take a while.
    Richard
    Quote Originally Posted by darenjones View Post
    I don't think it was a post by me.
    my bad, I got my water people mixed up! I meant Waterbear !
    OK, when do I consider clarifier ? or a floculant ?
    I have been after the water for about 2 weeks now
    FC 5
    CC 0
    TC 5
    PH 7.2
    Alk 80
    CH <1
    CYA 55
    temp 75
    Water is still slightly cloudy, can see bottom, but not diagonal to other side.
    Any suggestions ? kept the chlor at 11-15 ppm (per the CYA shock table) all week until yesterday (5 days)
    Any ideas ? Am I missing something ? Plus, I never got a response regarding the borax, and how to properly add... for PH and for Borates ?
