Thread: Pool patch recipe
    Default Pool patch recipe
    I need to patch a couple of worn spots in a plaster pool but am not ready to spend for a whole replaster job. I've been told to use a mix of white portland cement and white marble dust. Does anyone know the correct mix ratio to use? Thanks
    Hal
    Default Re: Pool patch recipe
    Quote Originally Posted by Sumo1 View Post
    Hal
    Still looking for help...
    GutierrezPlastering Guest
    mix 1 portland 2 marble dust if it fits in the wheel barrow; or 1/2 portland and 1 marble dust; mix for 5-10 minutes till you have a wet but somewhat stiff substance
  1. Super-simple recipe for Intex type swimming pools
    By PoolDoc in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-07-2018, 09:22 AM
  2. Moss all over pool bottom under liner - patch over?
    By skittles in forum In-Ground Pool Construction and Repair
    Last Post: 07-10-2011, 07:16 PM
  3. Is this too big to patch???
    By mariner09 in forum In-Ground Pool Construction and Repair
    Last Post: 05-29-2007, 05:40 PM
  4. Pool Patch
    By RENOPOOL in forum In-Ground Pool Construction and Repair
    Last Post: 05-22-2006, 07:33 PM
