It is normal to not show any combined chlorine. If you did the test correctly, you started with your pool water sample (25 ml or 10 ml depending on the resolution you want), you added 2 scoops of powder (R-0870), the sample turned red/pink, you then added drops of titrant (R-0871) and counted them, then the sample turned colorless and the number of drops was multiplied by 0.2 if using the 25 ml sample or 0.5 if using the 10 ml sample to get Free Chlorine, then you added 5 drops of R-0003 and IF there is any Combined Chlorine the sample turns red/pink and you add more titrant (R-0871) until it turns colorless. It sounds like your Combined Chlorine (CC) was zero and that's normal. Combined Chlorine is a bad thing, not a good thing, so having it at or near zero is what you want (and currently have).
Don't worry about your saturation index since you have a vinyl pool so don't need as much Calcium Hardness (CH) unless you've got some exposed grout in tile touching the pool water.
Did you mean 70 ppm for your CYA reading? 7.0 doesn't make sense. The tube only measures from 30 (at the top) to 100 (near the bottom).
You need to raise your pH as well as your Total Alkalinity (TA) so I suggest using Sodium Carbonate which is in Washing Soda (not Baking Soda) or is sometimes called Soda Ash or is in pH Up from the pool store. You need to add 116 ounces (7.25 pounds) of it to your 44,000 gallon pool (that's a very large pool) to raise your pH to 7.5 and your TA will rise to about 70 ppm which should be fine. Add half of this amount and retest pH after a day, just in case your measurements are off. Then add more as needed.
What are you using as your source of chlorine? The low pH and TA and the higher CYA imply that you may have been using Trichlor pucks/tabs. You should stop using those and switch to a chlorine source that does not have CYA in it such as chlorinating liquid or bleach (or Cal-Hypo, but this will increase calcium hardness over time). At your 70 ppm CYA level (if that is your CYA reading -- not the 7.0), then you need to maintain between 5 and 10 ppm Free Chlorine (FC) as seen in this chart in order to prevent algae.
Richard
