Results 1 to 8 of 8
Thread: Order of chemical additions...
    Central FL
    Default Re: Order of chemical additions...
    Thanks for the response Carl. I will do the Calcium first...probably tonight. I have some Calcium Hardness increaser (from pool store) leftover that I was going to use to raise CH. I can't think of what chemical exactly that it is...will that stuff work too? I'd like to get rid of it if I can...I can use the calcium hypo next time (i didn't even know they made that). Should I shoot for 250-300ppm do you think?
    Then I can do TA tomorrow evening. Then I can adjust the pH as needed (probably add some acid) Thursday morning. Then shock with bleach before I leave Thursday. Hopefully, my water will still look pretty when I get home Sunday night. Thanks!
    Quote Originally Posted by Henrys514 View Post
    It's calcium chloride and it's what you should use if you need to raise the calcium a lot. Cal hypo will not raise your calcium that quickly.
    When you add the baking soda add a small amount at a time dissolved in water and broadast it in the pool. If you see any local cloudiness develop you are adding too much at once and you need to add less at a time.
    Sounds like a plan. It's generally a good idea to wait about 24 hours after raising TA so the pool can stabilizer. There is a bit of chemistry going on in the water when you raise TA with baking soda but you should be ok.
    duraleigh Guest
    Evan,
    I have plopped it directly into the skimmer without dissolving. Is there a distinct advantage in dissolving and broadcasting?
    Depends on where your calcium is. If it's high it can cause clouding of the water. I am just being cautious since he is adding calcium and baking soda in a short period of time.
    Central FL
    Thanks waterbear. I don't normally like to add all the chemicals in such rapid succession, but my hands are tied in this case if I want it taken care of before I leave. I'm probably going to have to add acid Thursday morning, and then bleach shortly after that unless I can get someone to come and do it for me. My normal schedule is acid AM, bleach PM.
    If you have calcium and don't have cal-hypo, you don't need to buy cal-hypo. Just use what you have for the calcium and use whatever chlorinator chem you have for the chlorine.
    If you had neither the Cal-Hypo is a good one-step solution, but no need to buy it otherwise.
