Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 31
Thread: Lowering TA with Dry Acid Or Muriatic Acid
    Jul 2006
    Default Lowering TA with Dry Acid Or Muriatic Acid
    My TA is currently 230. It was recommended on another forum that I lower it according to the "HOWTO: Step-by-Step Guide to lowering your alkalinity" sticky. I read in my copy of "The Ultimate Guide to Pool Maintenance" by Terry Tamminen that you can lower TA by adding Muriatic Acid, or Dry Acid. Anyone try that?
    Ed
    Thanks,
    Ed
    33,000 Gallon
    20'x40'
    Vinyl
    IG
    Indiana.
    Default Re: Lowering TA with Dry Acid Or Muriatic Acid
    Sure adding acid lowers your TA. It also lowers your pH. When the pH goes back up, the TA goes with it, but when you aerate while the pH is low, the TA stays down.
    Tamminen gives the typical garbage the pool industry gives you. They love the "slug of Muriatic Acid" approach and give you a MacBeth Witches' explanation for why it works. If it does, it's incidental.
    There's really only one way, short of dilution with low T/A water to lower T/A and that's what's here. It's not always clear so here's how you do it:
    1) Lower pH to 7.0-7.2. (Muriatic or dry acid are both fine) This lowers T/A somewhat.
    2) Aerate your water. This raises pH WITHOUT raising T/A--and it's the ONLY WAY TO DO IT!
    3) Lower your pH again to 7.0-7.2, bringing T/A down some more.
    4) Aerate to raise pH again without raising T/A.
    5) Repeat until T/A is in the desired range.
    You "ratchet" your T/A down. T/A and pH are linked. pH goes up, T/A goes up. pH goes down, T/A goes down. ONLY BY AERATION can you break that cycle and do the raising of the pH without raising T/A, allowing you to lower it more the next cycle.
    The "standard" method only works if you have inadvertent aeration to raise pH that makes it look like it worked.
    Worse, the "Slug" of Muriatic Acid can do major, even catastrophic damage to your pool. If that "slug" comes to rest on a vinyl liner, with its 30% concentration of HydroChloric Acid, it can dissolve your liner or weaken it enough to fail.
    Jul 2006
    How do I aerate the pool?
    Ed
    Thanks,
    Ed
    33,000 Gallon
    20'x40'
    Vinyl
    IG
    Indiana.
    Quote Originally Posted by CelticDaddio View Post
    Ed
    A fountain, point the returns at the surface, or get a bunch of kids in there to splash around.
    Jul 2006
    You mean just a plain ol' fountain like this:
    And point the skimmer returns up to the surface?
    Ed
    Quote Originally Posted by JohnT View Post
    Thanks,
    Ed
    33,000 Gallon
    20'x40'
    Vinyl
    IG
    That's all you need!
    Jul 2006
    So my procedure to lower my TA is
    2) Turn on the fountain
    3) Lower pH again to 7.0-7.2, bringing T/A down some more.
    4) Turn on the fountain again
    5) Repeat 1-4 until T/A is in the desired range.
    Is there a formula for how much Muriatic acid, or dry acid to add to reduce the ph? I.e. 1/4 cups of muriatic reduces pH by 0.5, or is it not that simple?
    Last edited by CelticDaddio; 06-13-2007 at 12:30 PM. Reason: Added question about muriatic acid formula
    Thanks,
    Ed
    33,000 Gallon
    20'x40'
    Vinyl
    IG
    Yup that's it.
    In a 33,000 gallon pool, it is going to take about 26 oz. of muriatic acid to lower the ph by approximately 0.2. Don't try and get to your target in one dose. Small doses (maybe a pint at a time) added in front of a return jet slowly. Be careful not to splash any on you or on your liner. Also, don't breathe the fumes. Wait several hours to let it circulate, then retest and redose as needed.
  1. lowering Ph with citric acid
    By purplegirl in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-06-2011, 05:36 PM
  2. Where to buy Muriatic Acid
    By CelticDaddio in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-25-2007, 05:39 PM
  3. Lowering PH with Acid
    By aswetich in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-08-2006, 12:19 AM
  4. How much Muriatic Acid?
    By mccato in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-29-2006, 09:21 AM
  5. How much muriatic acid to add?
    By Blemished_Chemist in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-04-2006, 09:15 AM
