Results 1 to 10 of 10
Thread: Stabilizer
    Default Re: Stabilizer
    cal-hypo is just another brand of shock?
    Quote Originally Posted by mackeeg View Post
    Cal-hypo is another form of chlorine. "Shock" is actually a verb, something you do to your pool, instead of a noun, a thing. To "shock" only means to raise your chlorine level to a high level, no matter which form of chlorine you use to accomplish this. Some pre-packaged "shocks" contain cal-hypo or calcium hypochlorite, and are a much better chlorine alternative in your situation because it does not add CYA to the water like dichlor does.
  1. Is stabilizer necessary?
    By JimK in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-29-2012, 07:48 PM
  2. Stabilizer
    By cooper in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2011, 10:26 PM
  3. Stabilizer
    By Sue225 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-12-2011, 01:22 AM
  4. Stabilizer
    By Calcutta in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-26-2008, 11:31 PM
  5. HTH Stabilizer
    By let_her_flicker in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-20-2006, 07:57 AM
