Results 1 to 10 of 21
Thread: Wow.... Bleach consumption cut in half with a solar cover
    Default Re: Wow.... Bleach consumption cut in half with a solar cover
    I'm not sure where Spensar is getting his information. The insulating part is correct, but the heating part is not.
    Solar covers can be VERY effective at heating your pool. They aren't nearly as effective as solar panels but they do work. It's just a matter of how much heat you need.
    There's some debate as to whether opaque covers or clear covers work better. Opaque covers work by heating up and transferring the heat to the water by conduction. This does work and the water 4 to 6" below the cover will be quite warm, even hot. This then has to be distributed by the filter.
    Clear covers work by acting as a greenhouse. The sunlight penetrates the cover, heats the water but the heat is trapped, rather than dissapating up into the air. This, too can be very effective.
    Clear covers seem to work better when they are thicker providing more insulation.
    My personal opinion is that thick, clear covers work best, followed by other clear covers, which are pretty much the same as opaque covers. Blue transparent covers are the worst. They don't pass enough light to heat effectively, but they don't heat up enough themselves to conduct heat to the water.
    No matter the warranty all covers seem to go after about 3 years. They stretch (mine is already 2' longer than it was), then the bubbles start to pop. When they are rolled, it's best to keep them covered with a white opaque cover. Otherwise the sun bakes them and the inner layers get like an oven and start breaking down.
    One thing I don't understand is why opaque covers are blue on top and black on bottom. I would think that black on top would absorb far more heat to be transferred.
    Anyway, I've had experience with all three types and go for the thicker, clear covers now despite the expense.
    A good roller is also a must. Those plastic rollers do not hold up, but I'm much happier with a metal-framed roller.
    They are probably blue on top of the black for aesthetics - blue is nicer to look at.
    Ontario.
    Anyone I know in my neck of the woods that has a cover doesn't get much benefit from an increase in pool temperature. I am in Ontario and not in a real temperate area like you have in a lot of the US, so that is a caveat.
    I cover my pool daily and tried not running the heater to see what the cover does alone. It didn't do much for raising the temp - you may get a couple of degrees, and it is at the top as you indicated. But the thermocline is thin and in our 16x32 inground pool the net effect isn't much. Perhaps if you are looking to bring water at a not bad temperature up a bit to a more comfortable zone, the cover will have some effect. No way in our area does sloar cover bring what was colder water up 5 degrees or so. That is heat increases attributable to the incremental benefit of a cover since even without a cover the water temperature will increase in hot sunny weather.
    Anyway, that's IMHO and experience for conditions around Ottawa.
    I just didn't want someone buying a cover and thinking it will give them a heat boost and be dissapointed. That has happened to a number of pool owners I've spoken to around here. Often summer night temperatures are a lower temperature than pool water and the cover helps to preserve the heat, even without a heater. I would recommend a cover for that reason and take whatever heating as a bonus.
    I'll defer to the pros for other locations and my original statement may have been to broad.
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
    Upstate, NY (Dutchess County)
    I'm skeptical that the solar cover provides "heating" to the pool water. What the cover does for me is retain the heat when the temperatures drops at night (50~60*F around here recently).
    I used to watch steam rise from the pool in the morning over my morning coffee... no more...
    26,000 Vynil Liner L Inground
    Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
    Poolvergnuegen thepoolcleaner Pressure Side Cleaner
    Loop-Loc Mesh cover
    It does both.
    But if you don't have lots and lots of sun during the day (like 12 hours or more of direct sun) you'll not see a huge increase.
    Still, if you really want to heat your pool, combine solar panels with the solar cover.
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    It does both.
    I have a very Deep pool (11' 40,000 gallons) and the first 2 years I had no cover on it.
    These last 2 years I've had a clear cover and I can state with certainty that it does indeed make a difference (no experience with other colors). ~10 degrees for me if I keep it covered every night.
    I've noticed it helps a lot with evaporation which makes perhaps 80%+ of the heat retention. The water a few inches under the cover gets very warm but doesnt make a huge difference once you stir it up...especially in a deep pool.
    I've also tried the liquid fish and those do help but only 2-3 degrees at most under optimal conditions. They do make stuff float on the surface a bit better which helps keep the bottom a little cleaner...but thats hardly a reason so use them.
    Some people have hobbies.....I have a pool.
    Yeah, evaporation is endothermic so it sucks energy (ie, heat) out of the pool when a breeze is blowing. You lose water AND heat at the same time...plus you have heat loss due to convection--the warmer water rises to the top because it's lighter, it warms the air above it, which gets lighter and rises, dropping more cool air onto the water, which now has to heat it....etc.
    About a month ago when I opened my pool and put the solar cover on, it heated up about 3 degrees per day - went from 69 to 72 to 75 to 78 to 81 in four sunny days. I very much doubt I would have gotten that kind of increase without the solar cover, particularly since a couple of those days were sunny but not hot. Certainly, it helps the water retain heat at night, but I also think it adds heat, especially on a sunny day. I leave it on almost all the time, except in the middle of summer when the pool water gets too warm and feels like bathwater.
    stelr92 is offline ** No working email address ** stelr92 0
    I too would like to say that getting a solar cover has been a worthwhile purchase for my little 18foot round pool. I really like to have the water warm, and with the midwest heat that we have been having lately and abundance of sunshine, my pool has been sitting at a spa like 100 degrees for the last week now. I am just using a blue cheapie that I got for 60 dollars, I notice that after a good 4 - 5 hours of sunshine, the water in the first foot or so really heats up, so I have my pump filter set to go from 11:30am - 12:30pm, then again at 5:30pm - 12:00am so I can circulate as much warm water as possible. Last season without the cover the warmest the pool ever got was 82 degrees, and this was with a few straight weeks of 100+ degree temps! Other advantages include the amount of chlorine the pool needs has greatly reduced, and loss of water due to evaporation is also greatly reduced.
    We have had a variety of sizes of pools over the last many years, but 2 yrs of our larger pool - with all of them we use the blue covers, not the cheapest, not the most expensive. With the smaller pools (15', then 18') we saw a greater temp increase due to the smaller volume. We do use panels and have for several years so we try to differentiate the temp differences caused by each. The most obvious is the top 4-6" of water on very sunny days - SUNNY, not just warm because there is no difference there from the cover. Usually we can only tell that before the pump timer has come on or we have water circulation that stirs up that top layer to some extent.
    The cover KEEPS my generated heat in the pool
    The cover can (but does not always) heat the top few inches of water, mostly only when its hot AND sunny
    Another bonus is that the cover keeps additional crap from falling into the pool. I like that part - less cleaning for me.
    Cover = good investment
