Results 1 to 10 of 21
Thread: Wow.... Bleach consumption cut in half with a solar cover
    fog80 is offline Registered+ Thread Analyst fog80 0
    Columbia, Maryland, USA.
    Default Re: Wow.... Bleach consumption cut in half with a solar cover
    Quote Originally Posted by deanbrew View Post
    About a month ago when I opened my pool and put the solar cover on, it heated up about 3 degrees per day - went from 69 to 72 to 75 to 78 to 81 in four sunny days. I very much doubt I would have gotten that kind of increase without the solar cover, particularly since a couple of those days were sunny but not hot. Certainly, it helps the water retain heat at night, but I also think it adds heat, especially on a sunny day. I leave it on almost all the time, except in the middle of summer when the pool water gets too warm and feels like bathwater.
    what kind of cover do you have (color, opaque etc).
    I am looking at purchasing a cover and roller set from BJ's but I'm not sure if it is the right one.
    Caledon, Ontario, Canada.
    I recently went into a local major pool store and asked for a clear cover and they looked at me like I had rocks in my head.
    I suspect the "blue" idea was to attract attention to the "product" to help sell more.
    If you want to keep solar gain down in a car or in a room in your house, you tint the windows don't you ????
    So they tell me the blue cover generates heat. Yeah sure. Then they put in the air bubbles that create an insulation layer the keeps a large part of that heat on the top surface of the cover. No thanks. Give me clear. Let the radiation penetrate the pool as much as possible.
    My wife likes it at 90 degrees.
    We are heating a 16x32 IG with solar panels and have a lot of wind in top of the hill where the pool sits. The water loss through evaporation is terrific. Maybe Chem Geek can tell us how many calories are lost when 1/4" of water evaporates. It's a big number and will translate into a lot of degrees.
    I find the biggest reduction in loss is at night. To conserve your heat make sure you cover at night.
    If your pool is in a well protected area and not subject to much wind, covering during the day is not so important, but will still make a difference.
    With the tests I've tried, get a clear cover, run the pump intermittently so the water is moving under the cover and transfers the heat away from the cover resulting in less loss back up throught the cover.
    The "heavy duty diamond" covers are just that ... heavy. After they start to break down and some bubbles break and others lose the air in them, they don't float to well. That means water on top of the cover and that means evaporation again and ..... why did we put the cover on the first place ... to stop the evaporation.
    Get the lightest, clearest, cheapest cover you can find. It won't last anyway. Keep the water off the top of it. Protect it when its rolled up and you'll get the best bang for your buck.
    You can tell this is a favorite rant of mine.
    Good luck
    fcfrey is offline ** No working email address ** Thread Analyst fcfrey 0
    Central PA USA
    Just to throw in my 2 cents. I have had 3 different colors over 5 years --- silver, Blue and now a clear "Extruded" one. I bought this one from SPC this spring http://www.poolproducts.com/ I am very satisfied with this one and do get temp gain ---- the other thing they state is that they do not have to be covered when they are rolled up. Mine has a 10 year warranty (manufacturers defects) which does not mean much since they will blame failure on chemicals anyway.
    Quote Originally Posted by fog80 View Post
    Mine is just a basic blue cover, sort of like bubble wrap. Not the absolute cheapest, but fairly inexpensive. I'm sure there are colors and styles that might do a better job, but this one works pretty well.
    The ideal cover would totally block UV light so that chlorine won't breakdown from sunlight's UV rays. It would completely pass through visible light and most infrared. It would completely block heat from convection and diffusion (very little gets radiated back out from the pool as infrared -- it's not THAT hot) so would be a good insulator for heat.
    I don't think such a cover exists. Most that pass through sunlight seem to pass through a lot of UV. So the clear bubble pack variety are probably best if you want heating since they pass through most of the light while still being good insulators. If you want to minimize chlorine loss, then an opaque cover is best though a blue cover MIGHT block UV (since it reflects blue) while letting other visible light through (or it might let blue light through -- ideally it would be like blue-blocker sunglasses that look orange when looking through them).
    My own pool cover is an opaque safety cover and changes the heat loss at night from around 6F without the cover to 3F with the cover. If I had a true solar cover (bubble pack) the pool would probably lose half what it currently does -- probably around 1.5F. But at least I can roll mine with an electric motor so the convenience outweighed the lower insulating efficiency.
    Richard
    Kentucky
    5 years with my 18x36 IG in Kentucky. I started using a solar cover the first year. When it got a split personalily (delaminated) after the 2nd year, I didn't use a cover (3rd year).
    My pool gets tons of sun, from 9am until 7pm.
    My experience has been that 1) the solar cover holds in heat very well by way of stopping evaporation overnight. 2) I get a faster heat gain during the day WITHOUT the solar cover on.
    These are general rules that apply on 'average' summer days. At the beginning and end of the swim season when the daytime temps are cooler, or when the temp is below average, or it's going to be windy, the temperature is maintained better WITH the cover on.
    Regardless of your views on temperature gain, the reduced Cl usage is an undisputable fact. If you have the cover on during the day, you will lose less chlorine.
    CarlD's recommendation on the solar reels is on target as well. They are a must if you have a pool of any significant size, and the plastic reels have a limited life. Mine has a plastic frame on eihter side and an alluminum tube for the width of the pool. It's still working 4 years after I bought it, but I'll be lucky to get another 1 or 2. The sides are sagging and warping. (It's the Europa model, I purchased at Leslies).
    Good luck,
    Phantomandy
    18x36 IG Vinyl Grecian / Hayward H250 Heater / Hayward Sand Filter / Rainbow Trichlor Online Feeder / Treated using BBB and Trichlor Combo / Tested using the world famous (and now exclusive) PS233 Kit
