Thread: Chlorine went up unexpectedly
    Default Re: Chlorine went up unexpectedly
    If you check the thread you started on www.troublefreepool.com I gave an answer there that could possibly explain what happened.
    Downingtown, PA
    Thanks to waterbear and chemgeek. Appreciate your thoughts.
    I did not consider analysis errors due to diluting my 5cc sample for the colorQ. I also did not consider the CaHypo dissolving slowly. It makes sense putting the two together, would account for the FC rise to 22ppm and also the pool water cloudiness. Makes me feel a little bit more comfortable.
    The pool appears to be clearing up and the DE back pressure is staying at 22psi. Still do not know what hit the pool. I guess I need to super chlorinate more often? My shock in June was only a 2.5ppm increase since my CC was only 0.2ppm. The last super chlorinate (10ppm) was way back in May07. I also have been running chlorine a little low since I have the Nature2 system which is probably a risk, especially since I know I have a high phosphate level (2000ppm).
    Don
    30,000 gal concrete pool -- Autopilot SWG
    Using BBB for chemistry -- Using LaMotte ColorQ for testing
    This is one of the big problems with Nature2. If you had kept your FC at about 4 ppm (about right for your CYA level) then you would have had enough reserve FC in the water and you probably would not have had this problem in the first place.
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 10:28 AM
  2. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  3. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 06:00 PM
  4. alternatives to chlorine/non-chlorine pool maint
    By leewest in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-04-2006, 11:53 PM
