Re: New to BBB
Thanks for your help...
I realized after reading this site, that I was pool stored
. I think the UV shield was CYA, and I added it through the skimmer. However about two days after adding, I did backwash for a little bit. What will that cause?
We have had ALOT of rain here and I think that with leaving the pump on 24/7 has caused the water to clear up significantly.
Can you please answer a couple more questions?
What is stabilizer? Is it CYA? Our pool is 23000 gallons and the last test I did at home the CYA was about 55. Also is there a chart on how much to add (like 1 box of A&H washing powder will raise ph and alk. certain ppm).
