Re: LaMotte ColorQ Water Tester
OK. Here is my experience with the color Q. Got it a couple of weeks ago. Like the machine. All the test look good EXCEPT CYA! I have a CYA of about 50 and the machine shows 3 or 7 or 9 etc! After MANY conversations with tech support I was told that this is an issue with the machine and it is water temperature dependent. The temperature should be near 75 degree (mine is 81) to be accurate. The last conversation with tech support we left it at shipping the machine back to see if they can do better or receive a refund.
Regards
Amir
