Thread: Need help adjusting numbers, please
    Jul 2006
    Default Need help adjusting numbers, please
    Hi,
    My pool numbers are usually good (since I found this site - thanks!!), but a combination of a few days away on vacation and a LOT of rain followed by a high load (BBQ with ~55 people) has really knocked it off balance. I cannot seem to raise my pH, and I don't want to "guesstimate" any longer, so I am hoping for some assistance. (I went to the bleach calculator, but I'm not sure my calculations are correct.)
    I have a 16x32 vinyl in-ground pool with a diving bell configuration (I note that as it seems to increase the water volume calc a little bit).
    Numbers (on Fri) were FC 1, CC 0, pH 6.8 (I suspect true reading was much lower), TA 0, Cal 180, Cya 60.
    So far I have added 3/4 box borax and 8 lbs baking soda (Fri-Sat), and shocked the pool (last done on Sat).
    Pool no longer looks slightly cloudy, but it doesn't "sparkle" either. Current numbers are as follows:
    FC 7.0, CC 0.5, pH 6.8 (I'm guessing still <6.8), TA 60, Cya 60 (didn't do Cal again as it is a vinyl pool). I'm a little surprised that my Fc is as high as it is, especially as there were a lot of people in the pool, plus it has been ~90 degrees and sunny since Sat.
    I have soda ash available, or I can purchase borax and/or baking soda if that will work better for my situation.
    Thanks for any help you can provide!
    Laurie
    Jul 2006
    Default Re: Need help adjusting numbers, please
    Pretty please??
    Since you need to raise your alk and ph, you can use soda ash or if you prefer, you can use Borax and baking soda. Either will be effective. Aim for a ph reading of 7.4-7.6 although anywhere between 7.2-7.8 is OK and a TA reading between 80-125. After you add stuff, wait 4 or 5 hours to let it circulate and then retest and redose as needed.
    Jul 2006
    Thank you, but I'm still a bit lost - my original problem was (and still is) "how much [soda ash OR borax OR baking soda] do I need to raise pH by "X"? Can anyone give me an idea as to how much product to add to start?
    I'm sorry for any poor phrasing re: what I need to know! Thanks again~
    mbar's Avatar
    Ashland, PA
    Here is a "bleach calc"
    BleachCalc262.exe
    Go to the top left and click on "more calcs" and you will see where you can put in the info on how much you want to raise or lower your numbers
    Northeast PA
    Jul 2006
    Quote Originally Posted by kdzgon View Post
    ...I cannot seem to raise my pH, and I don't want to "guesstimate" any longer, so I am hoping for some assistance. (I went to the bleach calculator, but I'm not sure my calculations are correct.)...
    Thanks for the link, mbar but as I said I was already there. I'm not sure of my pool volume so I was asking for help in running the calcs.
    When I purchased the kit, it was suggested I post my numbers here to get help on computing the numbers to adjust my water rather than just guess at doses, so that is what I did. I've gone back to the old style of just keep adding and testing until I get close, and if I over-shoot my goal, I'll just adjust the other way.
  1. help adjusting
    By poolhelp101 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-17-2012, 08:27 PM
  2. Pool's Clean- Need help with adjusting numbers. =)
    By JenLM in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-16-2011, 11:38 PM
  3. adjusting alk, PH, and cl
    By spongebob55 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-23-2007, 07:02 PM
  4. help with adjusting please
    By poolhelp101 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-05-2007, 10:03 PM
  5. adjusting low pH
    By fullhouse in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-25-2006, 02:49 PM
