Thread: 2 speed pump. High speed puts sand in pool?
    mjs31 is offline Registered+ Thread Analyst mjs31 0
    Texas
    Default 2 speed pump. High speed puts sand in pool?
    I have the pentair Dynamo 2 speed pump (3/4 HP). I run it in low speed 99% of the time, but on certain occasions I need to put it in high speed to circulate quicker. Every time I do this, I get a bunch of sand, from my sand filter, on the pool bottom. Is this a mismatch in filter to pump or what else should I be looking for? My pool is a 24' AG 54" high pool.
    By the way...I never get any sand in low speed.
    Default Re: 2 speed pump. High speed puts sand in pool?
    Quote Originally Posted by mjs31 View Post
    Sounds like the pump at high speed is just too powerful for your filter. What size is the filter?
    Texas
    I wish I remembered. It is a waterway that came with the pool. 150lbs of sand I know for sure.
  1. If you run a variable-speed pump at half-speed, does the turnover rate double?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-25-2012, 01:22 PM
  2. I have a 2 speed pump - when to use low? When to use high?
    By Jacob99 in forum Pool Equipment & Operations
    Last Post: 05-03-2012, 09:52 PM
  3. 2 Speed Century Pump Motor is now only 1 speed
    By TelexBill in forum In-Ground Pool Construction and Repair
    Last Post: 10-14-2011, 10:40 PM
  4. Pump sputtering bad on start up (high speed)
    By mjs31 in forum Pool Equipment & Operations
    Last Post: 10-15-2007, 01:39 PM
