Results 1 to 10 of 17
Thread: Happens to the Best of Us
    Default Re: Happens to the Best of Us
    Quote Originally Posted by mbar View Post
    You know the drill - bleach, bleach, bleach oh yeah, and POP
    Yup, I know the drill. After all, I've written it about 100 times! And it's working. Bleach/LC 2-3x/day, filter 24/7. Backwash as needed, vacuum and brush everyday (thank goodness for my Blue Diamond) and lots of POPP.
    Even though the water was cloudy tonite my FC was 10 and my CC was .5-1.0. Added another gal of 12.5%...which should take it to 16ppm--just above shock level for my CYA.
    It's getting clearer and the process is working. I have POPP, too.
    zephans is offline Registered+ Thread Analyst zephans 0
    Bothell, WA
    POP? POPP? Sorry, I haven't heard that term yet. Quick definition please? (My guess is POP=Plenty of patience but I have no idea what POPP is. POOP = what you said when you got back to find a marsh instead of a pool.)
    Thanks! -ZephanS
    AG BF 13.5'x23.5'x54" (wups) Diamond Star (Wil-bar) purchased 5/30/2007 from sunenterprises.com. 2hp pump + 150lb sand filter (both WaterWay combo) using 75lbs zeobrite + SWG.
    Dug and built ourselves in ~30hrs by ~7/4 thanks to PF (esp. hrdennis,nwmnmom,matt4x4,Waste,CarlD, &others). ~$5,500 total cost.
    Ontario.
    Talking Re: Happens to the Best of Us
    Chairman Mao was a great adovcate of returning to work the rice paddies once in a while!
    Failing that, just paypal $299 to Spensar'[email protected] and a representative will deliver a magic solution. Please be sure to follow the instructions carefully: it must be used with your filter on and the level of chlorine as per the instructions. If followed, guaranteed to kill the algae!!
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
    mbar's Avatar
    Ashland, PA
    Hee hee, there are a lot of ways get parted with your money, but thanks to all on this forum we have learned how to avoid this with our pools - now for the rest of my house????
    Northeast PA
    POPP: Pool Owner Patience and Persistence!
    Magic goop--just like instant water: Fill a cup from a drinking fountain water, add Instant Water, stir and VOILA! water!
    karrde97 is offline Registered+ Thread Analyst karrde97 0
    Peoria, IL
    I has the same problem in June when it rained all the time. Took about a week to get cleared up.
    We got a bunch of rain again a couple weeks ago. I managed to catch it in time. I started pump 24/7 and tons of bleach when it was getting cloudy. Still took a week but I got it.
    I've got a HUGE box of DE I bought at Lowe's when I only needed (1) Cup. I didn't think about adding that. I'll do that next time.
    21' AG 48" AquaLeader
    Central Illinois
    Quote Originally Posted by karrde97 View Post
    Don't add too much--1/3 to 1 cup is all you need--if your skimmer stops working, just backwash the filter and add less DE. You need to add more DE everytime you backwash. Actually, you don't need to add it, but if you want the extra filtering DE gives sand you do. I have been using DE for 2 1/2 seasons now and STILL am on the first 10 lb box. DE doesn't go bad.
    My pool's now pretty much clean. The water is clear but not the crystal, crystal clear I like and usually have.
    We had a lot of rain while I was away and I think that did it.
    Update:
    My water is nearly as clean as I like it!
    FC: 8
    CC: 0
    TC: 8
    pH: 7.3
    T/A: 90
    CYA: 38 (approx)
    CH: Who Cares?
    Temp: 78
    I realize I had JUST a little too much DE in the sand this morning when I saw that at low speed the pressure was 20 psi! But after a back wash and less DE it's fine!
