Thread: What type of PVC Glue?
    NJ
    Default What type of PVC Glue?
    I need to replace a 3 port valve which entails glueing some pvc parts.
    I know there are a number of pvc glues.
    What type of glue is recommended?
    20x40 IG vinyl; ~25,000 gal; Hayward EC75 DE Filter; Polaris 360 w/ booster pump
    Default Re: What type of PVC Glue?
    If you are using hard PVC, not flexible, for all pieces, then they all should work. For flexible PVC, use the blue stuff.
    NJ
    at one joint i'll be connecting sch 40 to the flexible pipe coming from main drain & skimmer.
    Quote Originally Posted by wetshoes1 View Post
    Use the blue stuff. You can use it for everything anyway, but it's better for the flex.
  1. Boxer Glue: What did I Do Wrong?
    By CarlD in forum Above-Ground Pool Construction & Repair
    Last Post: 08-09-2012, 09:39 AM
  2. Can I glue a threaded pipe into a smooth pipe??
    By adl6009 in forum In-Ground Pool Construction and Repair
    Last Post: 06-21-2006, 12:19 AM
  3. Boxer Glue?
    By SherrySt in forum Above-Ground Pool Construction & Repair
    Last Post: 06-17-2006, 12:49 PM
  4. What type of chlorine should I use?
    By seabee1 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-06-2006, 05:36 PM
  5. What type of filter should I use?
    By prh129 in forum Pool Equipment & Operations
    Last Post: 03-29-2006, 01:14 PM
