Thread: Pool uncovered all winter/Ph question
    Smile Pool uncovered all winter/Ph question
    Have a couple of quick questions:
    First tested the PH and it is higher than 8.2 This was taken before I added any Chlorine. Is it possible to get a false high PH? I have added some M. Acid and color changed somewhat (I dont see reds very well).
    Next, took Cl up to 20 last night and dropped to 10 by sunrise. On top of the water I noticed a light foam. This started after adding CL to water. Is this something to be concerned about?
    I know next year i will start adding chlorine to pool water in February to prevent a green swamp that I currently have. It did go from dark green to an aqua green in one night.
    Last edited by let_her_flicker; 04-14-2008 at 09:14 PM. Reason: Information I forgot to note
    Default Re: Pool uncovered all winter/Ph question
    Quote Originally Posted by let_her_flicker View Post
    Doesn't sound bad to me, there may have been something which raised the pH, but because high cl throws off the pH test, I'd deal with the green first - if you had had low pH I'd have said to wait until the pH was in check before shocking. I've seen the foam, usually with a salt pool and an ammonia algaecide - it eventually clears up. As long as you continue to keep the cl up, the water will continue to clear and, once the 'green' is gone and you can drop the cl low enough as to not interfere with the other tests, you can deal with them then. Depending on your type of pool (liner, fiberglass, crete) and the other #s (alk, cal and cya), it's probably better to have a higher pH than a lower.
  1. Pool water level / winter cover question
    By Rick H in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-24-2012, 06:46 PM
  2. Leaving Pool Up In Winter
    By joslinm in forum Above-Ground Pool Construction & Repair
    Last Post: 08-22-2012, 02:52 PM
  3. winter pool
    By borrott in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-29-2007, 02:53 AM
  4. Any harm leaving it uncovered?
    By JBfromNJ in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-30-2006, 12:28 PM
  5. Uncovered Our Pool Today!
    By aubratgyrl in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 03-30-2006, 01:38 PM
