Re: How much/which chemicals needed in newly filled pool?
One more thing, the guy that is going to replace the liner recommended I use Lithium Hypochlorite for chlorinating because its better for the liner and then bleach. I keep my CYA and chlorine low so I don't think using bleach should be wearing out the liner. Do you have any experience with Lithium Hypochlorite? Does it come with stabilizer like tri-chlor?
