Thread: High TA, low pH
Threaded View
  1. #4
    Default Re: High TA, low pH
    The threads you see about raising borates is a theory that some are trying that says if your borates are at 50 (adding Borax is how you raise borates), then you use less chlorine to maintain the same sanitation, since the borate level apparently has some anti-algecidal properties. High borate levels are also though to stop the creeping up of pH in pools that have a SWG. The people who are raising borates are adding Borax, then adding muriatic acid to compensate for the rise in pH, so the borate level rises but the pH stays within normal levels. You can read more about the Borate theories here.. http://www.poolforum.com/pf2/showthread.php?t=4712.
    When you add Borax to raise your pH level, the TA will rise slightly--but even a slight rise in your case will contradict your purposes, which is why Carl says to aerate your water to get your ph back up. If you aerate to raise the pH, and have NO rise in TA, then you can again lower both with muriatic acid, again aerate to raise pH back to normal, and thus accomplish your goal. If you're using acid to lower pH and TA, then add Borax, you'll never get the TA down.
