Results 1 to 10 of 20
Thread: Looking for a good sand filter
    Cleveland, OH
    Default Looking for a good sand filter
    I have a 24' Above Ground pool and looking for a sand filter. I have a cartridge filter and am sick of cleaning the cartridge. The filter I have I lose a lot of water in order to take the filter apart to get the cartridge out. It such a pain.
    What filter would you recommend?
    Thanks,
    Frank
    Default Re: Looking for a good sand filter
    I have a 24' AG also. Don't know the model, but I have a Hayward 200 lb. filter and it has been easy to maintain for the past 8 seasons. Bought a new pump last year - 1/2 hp Hayward to replace a 1 hp pump. The smaller pump has been plenty for my pool along with my filter. I don't blame you for wanting to get rid of a cartridge filter. I know I wouldn't want to fool with having to clean one, although some people like them.
    Cleveland, OH
    Thanks for the reply. I am thinking I will stick with hayward since that is what I have currently. I am happy with everything but I just dont like the pain of the cartridge and since its such a pain to clean it doesnt get done as often as it should. I know this casues me issues with my water clarity.
    What type of sand do you use for the filter? Normal play sand? Also can I use some DE in there?
    WOW 1/2 hp pump? When I got mine a few years ago they sold me a 1.5hp pump. I guess its WAY overkill. I figured I should probaly have a 1hp pump now that I know more about pools.
    Also what do you do in the winter to winterize the pump? I wouldnt think you would move the 200lb filter.
    Thanks,
    Frank
    Only use pool filter sand. No play sand. Yes, you can add a little DE to your sand filter. Carl, Al, and I do it and get good results. Add only a little -- enough to raise the pressure by 1 psi. Wait awhile after you add it before deciding you need to add more because you won't necessarily see an immediate rise. If you add too much, do a quick backwash and blow it out and then try again with a smaller amount.
    As far as pump sizes, 1.5 hp is way too powerful for your pool. When my 1 hp pump died last year, I let Al, (Poconos), my fellow moderator and our resident pump expert pick out my pump. He chose my 1/2 hp pump which he felt would be adequate and save me some money on energy costs. I initially thought it wouldn't be powerful enough, but he was right. It has been perfectly adequate for my pool. He is an electrical engineer and knows what he is talking about and when he recommended it, I trusted his opinion. Turns out, he was right. (Hear that, Al? I am saying you are right about something. Not everything, mind you --- but about my pump, you were!! )
    For the winter, some years, after we drain it, my husband has wheeled it into our shed for the winter; sometimes we just open the plug and cover it with plastic and leave it outside for the winter. We typically do have to replace the pressure gauge each year, but that is cheap so it is no problem.
    Hope this helps.
    Cleveland, OH
    ANy idea of cost on the sand?
    How much of a power savings would you say is the difference between your old and new pump? I need to see if I should sell my old pump and buy a smaller one.
    Honesdale PA
    If you measure the running current and know your electric rates you can get a close $$$ savings number. I never measured anything for savings purposes. At 100% efficiency, which is not the case, it is 746 watts per HP. So multiply by 1.5 as an efficiency fudge (just a guess on my part) and you have around 1100 watts per HP. Running a 1 HP pump for 1 hour with my ficticious efficiency fudge factor and you have 1.1 KWH (kilowatt hour). For a 1/2 HP pump it would be .55 KWH. If the electric rate is 10 cents per KWH you save around 6 cents for every hour as the difference between a 1 and 1/2 HP pump. If you run it 8 hours a day that's about a 50 cent per day saving, or about $15 a month. That little 6 cents an hour adds up. Another consideration is lower HP thus lower flow yields better filtering.
    Quote Originally Posted by MaxxFusion View Post
    Filter sand is sold in pool stores in 50# bags. It can be as low as $5/bag or as high as $13.- Shop around. If you see it for under $10, buy it. On a 200# filter, that's 4 bags....$20-$40 for your sand--and you'll have it for many, many years if you follow our suggestions. I'm the newbie here--my sand is super-young---only in its 6th season. Watermom is in season 8 or 9 and Poconos is at, what? 13 years, Al? So, if it costs you another $20 for something you'll use for 10-20 years, why spend $20 in gas to save $20 on sand? Just MHO.
    There ARE tricks to easier cleaning of carts, but I don't really know them other than soaking it in electric dishwisher powder. And there's a new hose-mounted brush that's supposed to work well. Still, if you search PoolForum, you should find those techniques.
    I had a small cart for a 15' Intex donut I used for 3 years. I couldn't figure out how to clean them very effectively, but they were only $10 each so I could get a month out of them--$30 for the summer here in NJ. Personally, I hate carts (like Watermom), but that's me. Other folks SWEAR by them, so before you replace it, you might want to search this and other Internet forums for techniques that make cleaning carts far more painless.
    Good luck!
    Cleveland, OH
    Thanks. I was looking for a 1/2 hp version of my hayward power flo matrix and didnt see one on their site. What is a good 1/2 hp pump?
    Cleveland, OH
    Good luck!
    Actually its not the technique thats the problem. I found that using my power washer works very well to get all the gunk out. Its just a pia to get out the pressure washer, drain the filter each time, and ten pull out the cartridge. I find myself not doing it as much as I should and then the water doesnt get filtered correctlybecause of the dirty filter. Not to mention that the cartridge is about $70 or so.
    Honesdale PA
    Check this site:
    http://www.inyopools.com/pumps_hayward.aspx
    they are in Florida and I think that's where we got Watermoms pump and I'm pretty sure it was the SP2600X5. Stick with the IG pumps. They are maybe built better but the pump basket lid opens easily compared to the twist off AG pump baskets. That may be a 'general' statement. Took only 2 days for delivery if I remember right. This is the same series as my 1 HP that has been running for the 11th season now. If at all possible put it in a shelter to keep the weather off the thing. Any pump exposed to the elements will suck in water droplets when it rains and that shortens the life and makes it a dog to take apart in its later years. Someplace on this forum something like a fiberglass cover, open at both ends, was discussed. Have no idea when or where to find it but a little Googling should turn up something.
  1. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 11:41 PM
  2. Cartridge filter cleaner any good?
    By GCALAHAN in forum Pool Equipment & Operations
    Last Post: 02-29-2008, 05:45 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
  4. suggest a good sand filter/pump model combo for 24' AG
    By ScottS in forum Above-Ground Pool Construction & Repair
    Last Post: 04-01-2007, 01:06 PM
  5. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 01:01 PM
