Results 1 to 8 of 8
Thread: Hazy water
    Dec 2005
    Jupiter, Fl.
    Default Hazy water
    My water gets cloudy with any significant bather load and hasn't totally cleared up after 2 days. Filter run time is at 10 hours/day. All chemical parameters are within range. I clean the cartridge filter once/month. It is due to be cleaned this weekend. New Filter was purchased in April. Technically speaking, the water is fine but the haziness of it bothers me. Any suggestions or should I just leave well enough alone? Thanks.
    I live in South Florida. I have owned my first pool for 6 years now. 12,200 gal. with exposed aggregate finish, spa with spill over, cartridge filter, pop up bottom cleaning jets, Chlorine by swg. I am eternally grateful for The Pool Forum!!
    15'x30' Rectangle w/ ovals at ends 12.2K gal IG pool; Bleach now as SWCG died.; Hayward 1200 cartridge filter; Emerson 2HP pump; 6hrs; Taylor K-2006 La Motte Borate Test Strips; utility; summer: ; winter: ; iPad; PF:9.8
    Indiana.
    Default Re: Hazy water
    Quote Originally Posted by DennyB65 View Post
    Post your test numbers. Nobody can advise you without your results.
    Dec 2005
    Jupiter, Fl.
    Test Results are as follows:
    P.H. 7.6 Parameters are consistent as I test my water very often.
    Cl 4.0 (3 to 5 times a week)
    T.Alk 90
    cya 90
    Bought a Hayward cartridge to replace the after market one I had purchased at Home Depot just 2 months ago. When I took out the old cartridge it was loaded with a yellow substance and the filter was just filthy in general. I clean my filter once a month, this has always been adequate in th past. After installing the new cartridge i added some Jacks Emerald stuff and the haziness of the water cleared up significantly. However, when I brushed the pool today I was getting a yellowish looking dust coming up off the bottom of the pool that I was only able to see with my polarized sun glasses on. I kicked up my aqua rite to 100% and running my pump 10 hours/day. Water temp is 90 degrees give or take. We have had some significant forest fires in So Fla as well. I would really appreciate any input that the experts may have. Let me know if you need any more info.
    rnjng Guest
    i hope this has relivency. bens best guess chart shows the cya/stabilizer numbers and the respective clorine levels that should be maintained accourdind to the stabilizer. your cya is at 90 which shows that your min. fc should be 5, and max. should be 10. I hope this is my correct understanding can someone please verify.
    here is the link for bens chart
    http://www.poolforum.com/pf2/showthread.php?t=365
    Stabilizer . . . . . . Min. FC . . . . Max FC . . . 'Shock' FC
    => 0 ppm . . . . . . . 1 ppm . . . . . 3 ppm . . . . 10 ppm
    => 10 - 20 ppm . . . . 2 ppm . . . . . 5 ppm . . . . 12 ppm
    => 30 - 50 ppm . . . . 3 ppm . . . . . 6 ppm . . . . 15 ppm
    => 60 - 90 ppm . . . . 5 ppm . . . . . 10 ppm . . .. 20 ppm
    => 100 - 200 ppm . . . 8 ppm . . . . . 15 ppm . . .. 25 ppm
    In other words, your chlorine level is 'way too low. That was obvious when I saw it was 4.0 (Total C, not FC) and CYA=90. 90 implies keeping your FC close to 10--the 5 to 10 range is for 60-90. You're at the top, keep your FC at the top.
    That's the most obvious reason for your clouding...you don't have enough chlorine. To lower CYA, you have to drain off water. If you drain half your water your CYA will be half.
    Don't chlorinate with Tri-chlor tablets or even di-chlor powder. Stick strictly to bleach and liquid chlorine or the problem will get worse.
    Good Luck!
    Dec 2005
    Jupiter, Fl.
    I am running an aqua rite SWG. The manufacturer says to keep cya @ 80 to 100. I guess I will always need to have my Cl at a 5 or higher. Especially with high So. Florida summer water temps. ( 90 + ). How often should I clean my cartridge filter and should I add anything to else to the water besides increasing chlorine to get rid of the yellow substance?
    OK, I didn't see you had an SWG. The rules are a little different. But I would raise the FC to 5 minimum. Still, I'll let the experts comment on proper SWG usage.
    If the yellow is pollen, I find the BEST way to fight it is a skimmer sock in the skimmer, and clean it twice a day. It catches most of it before it gets to your filter.
    I brush the pool daily to keep it stirred up, and let my filter take care of it.
  1. my pool water is hazy what must I do ??
    By jesse in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-27-2012, 02:26 PM
  2. Hazy water
    By Dan Heinrikson in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-31-2012, 10:00 PM
  3. Water balanced, new filter, still hazy...
    By sunlove in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-23-2012, 12:08 AM
  4. Hazy water - how much shock?
    By drband in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-06-2006, 08:38 AM
