Thread: cloudy water all summer?
    Default Re: cloudy water all summer?
    Guess I didn't realize how much CYA we lost when drawing down the pool after all the rain. The CYA is in the skimmers as I type, and am bringing down the pH. Will test in a few hours and keep bringing pH down to 7.2.
    The calcium hardness is 120 (purplish) to 130 (blue).
    How do I test forthe level of Borates? I have Borax.
    40,000 gal. DIY IG vinyl pool , Zodiac SWG, sand filter w/ Zeobrite, 3 Aqua Genie skimmers, 2 HP pump, pavers
    Quote Originally Posted by hsdancer View Post
    With this low a calcium then the cloudines is probably not from the calcium preciptating out (unless it was higher and already did) but probably from the chlorine getting spot depleted in the pool because of the low CYA. If dropping the ph has no impact on the cloudiness then it's the CYA level. If it clears the pool then retest your CH. You will probably find that it went up as the calcium carbonate redisssolved.
    This link should tell you all you need to know about adding borates.
  1. Total Confusion - Last summer no probs but this summer big problems
    By ADHDPoolOwner in forum Pool Equipment & Operations
    Last Post: 06-14-2013, 02:01 PM
  2. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
  3. ph and cloudy water
    By itjustrixie in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-29-2007, 05:05 PM
