Re: Chlorine Lock ????
I did do the stick test for ammonia, I will pick up the other ammonia test kit they had in the store that uses drops and a color card , similar to the pool 5 way test kits. I know for sure I put in 3 gallons of ammonia on start up by suggestion of the new pool guy (who I don't use anymore). Can 3 gallons in a 33k pool , do so much damage ?? How do we get rid if it is ammonia, maybe we should treat it as such even with the stick test showing negative. ??
