Results 1 to 10 of 11
Thread: Full opening instructions?
    Default Re: Full opening instructions?
    I can take a tease! I've corrected the offending misspelling above.
    Evan, thanks for the compliment. I may have depth in pool water chemistry theory in some narrow areas that Ben did not, but he had breadth and experience that is unmatched. I miss him.
    I was referring to the behind the scene work you have been doing on the new standards for pool watern that you have alluded to at times.
    Heck, Evan, no wunder! Yoo kent spel two gude eether
    (besides, I only make fun of friends--I'm sarcastic and belittling to all others!)
    So is that making fun or being sarcastic and belittling?
    (And did you ever think that I might have misspelled on purpose!)
    You'll never know!
    You'll never know!
    Neither will you!
    Neither will you!
    I never said I did....
  1. How full is full on an easy set pool?
    By Larryh86GT in forum Intex-type Pool Setup & Operations
    Last Post: 06-28-2013, 11:02 PM
  2. Help with test kit instructions
    By kevincad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-12-2007, 11:33 PM
  3. Leslie's (Same as Poolmaster?)OTO Kit - Need Instructions
    By pspercy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-12-2006, 02:56 PM
  4. Where are the instructions for PS234
    By ksturge in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-05-2006, 10:44 PM
  5. Need instructions on opening a pool
    By littleHeidi in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-12-2006, 10:38 PM
