Thread: Container to Clean DE Grids
    Mahwah, NJ, USA.
    Default Container to Clean DE Grids
    Anyone have a suggestion for a container to clean DE grids in?
    Tried a garbage can last time but it tipped over, not good when cleaning with Muritac Acid. Thinking of something plastic, shallow and no top that I can lay on the ground. Heyward Pro Grid DE 7220. Thanks
    Default Re: Container to Clean DE Grids
    Quote Originally Posted by donfranko View Post
    How about a mortar mixing tub? They are flat and can resist the aggressive corrosive action of the concrete's lime.
    Don, you could get one of the plastic storage containers from Wallyworld, etc.
    If you leave the grids in the manifold, you'd have to turn the unit to soak the other 1/2, if you just soak the grids, you could do all 8 at once
    Please remember to do a degreasing soak on the grids BEFORE dipping them in acid!!
    Have a great pool season!
  1. Filter Grids, DME
    By Pharmer in forum Pool Equipment & Operations
    Last Post: 04-25-2012, 05:35 PM
  2. Will a sealed container of water hold chlorine forever?
    By sunofthebeach in forum General Interest
    Last Post: 07-25-2010, 05:10 PM
  3. ML measuring container
    By donfranko in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-02-2010, 12:27 PM
  4. Cleaning DE Grids
    By donfranko in forum Pool Equipment & Operations
    Last Post: 05-17-2008, 06:37 PM
  5. DE Filter Grids
    By mkamp1515 in forum Pool Equipment & Operations
    Last Post: 04-04-2007, 05:10 PM
