Thread: cartridge to sand / pump size ect...
    Howell NJ
    Default Re: cartridge to sand / pump size ect...
    Well, I have a similar pump--Hayward 2spd Superpump with 1 hp full-rated and I run a 200lb sand filter with no trouble. It's not as simple as that--it's all about flow rates and feet of head and a lot of stuff I don't understand either. So rule of thumb goes.
    I think for now you will be fine running on low 12 hrs a day-- it's still cheaper than 6 to 8 hours on full.
    I've never heard of gluing in a spider gasket. Maybe it's a brand thing or the store guys are lost. If it looks like O-ring rubber, only as a spider web, I STILL think glue is a rotten idea.
    I actually think you have something stuck in the multi-valve mechanism that's keeping it from closing the chambers properly. But that's a guess.
    One more thing. I thought my old cartridge was 3 yrs old. I see I became a member in 2004. That would make the filter cartridge going on its 6th yr. Mabye I should have just bought a cartridge since I got my yrs out of the original. The cartringe filter is rated for 80 gallons max and this sand filter is rated at 35. Hmm what to do. I have two fiters. . I also have the oringinal one speed matrix pump. Mabye I could sell that to recoup my costs and start over. I could sell this sand filter also and go to a 200lb unit. I am unemployed since oct, and really am on limited funds.
    What to do... what to do.... I wish someone says the 1hp is fine for that sand filter. Not!!!
    Mike Howell NJ
    Call the manufacturer.
    Howell NJ
    Quote Originally Posted by Lawrosa View Post
    Mike Howell NJ
    Well I got this off the Hayward site. I used Silicone and not Crazy Glue. The 3 m stuff I think is expensive. I let it dry 4 hrs.
    No More leak out waste. Here is what I found.
    Question.
    Why does my multiport valve leak out of the backwash line?
    Answer.
    The valve seat gasket inside of the valve may have become worn or loose. If this is the case, you will need to replace the gasket. With the pump off, remove the cover screws of the valve.
    NOTE: Mark the top and bottom of the valve with a marking pen. It's very important that you do not change the location of the cover when re-assembling. Some newer valves will have a flat spot along side one of the cover screws. When re-assembling, align the flat spots.
    GENLTY remove the old gasket and glue, ensuring the channels are clean and clear. Use 3M adhesive, part number SPX0710Z9, or crazy glue**. Lay a bead of adhesive into the channel where the gasket sits. Place the flat side of the gasket into the channel. Apply pressure to firmly seat the gasket and let dry for 24 hours or contact your Authorized Hayward Dealer for repair.
    **Crazy Glue – Use caution when using crazy glue. You will have only ONE chance to seat the gasket
