Re: Main Drain - Can"t run pump off MD
Got strainer pump lid off with the mallet. Thanks!
Still cannot get prime running pump off main drain - I have 3 gate valves (main drain, pool skimmer, and spa skimmer) When I open the Ball Valve to the gate valves the pump loses prime immediately.
My pool guy says I have a leak somewhere and that he did not see any anti freeze from the pool close.
Any ideas where to go from here. ????
