Results 1 to 10 of 17
Thread: Who has an Intex Ultra Frame 24' pool?
    Jun 2010
    Default Re: Who has an Intex Ultra Frame 24' pool?
    Thanks for the input guys. Couple questions if your don't mind.
    1. Is the Diameter of the pool once it is filled really 24'? Is that from outside of Rail to outside of Rail? This is a critical measurement for me I cannot locate. Help is appreciated.
    2. I was thinking of getting a sand filter and pump but didn't really want to put $700.00 into one. Any suggestions or experiences here?
    Thanks alot for the help.
    Jim
    sturev's Avatar
    sturev is offline Registered+ Thread Analyst sturev 0
    May 2010
    Jim, you might want to post #2 as a new thread with that title and you'll probably end up with a lot of feedback...
    Evan S.
    AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
    May 2010
    I put a sand filter on mine just about two weeks ago. It took a little imagination to plumb it between my Intex pump and SWG, but it works and its AWESOME!! I used a 200# filter from ebay for $230 free ship. Its blue with a white valve assemly on top if you go looking for it. My pool was NEVER so clear as it is now. As an added benefit, I left the Intex filter assembly intact, so if I wanna use cartridges, its still there. I can put the sand filter on recirculate, and drop a cartridge back in the Intex canister, and poof, back to cartridge. Not that I would ever want to. With sand, plumbing, and backwash hose, total cost was right at $300. And that's a filter rated at 3300GPH, and 21k gallons. Seems to be the perfect amount of overkill. About 35%. I can send pics of my setup and plumbing if you want to see how I did it.
    I'm workin on lighting now.... :-)
    Quote Originally Posted by jkoch View Post
    Just to make a comment--Intex filters are notorious for being undersized, so if you can afford to add a sand filter, I don't think you'll be sorry--ESPECIALLY if you ever have an algae bloom to clear up. I have a friend that has the 15' Intex pool that let an algae bloom get the best of her and asked me to help her get it cleared up. We had the algae dead in two days, but it took almost a week of 24/7 filtering (and I don't even want to count how many times her hubby had to clean the cartridges) to get it cleared up again. A sand filter really comes in handy if you have water problems to take care of....
    May 2010
    That was my experience as well. The pump seems to be adequate at best but the filter was totally NOT. Have trees and pollen issues, and was having to clean the filter twice a day and pool was still cloudy. Still have to backwash everyother day, but it's way easier than cleaning that cartridge, and pool is crystal clear no matter how bad I abuse it. You definitely will not be dissapointed in a sand filter.
  1. 16X48 intex ultra frame
    By td51902 in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-24-2014, 07:35 PM
  2. Intex 14x48 Ultra Frame Pool
    By Blmcmillian89 in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-04-2013, 01:43 AM
  3. First time adding chemicals to 18x48 intex ultra frame pool..HELP!
    By babyblueiz77 in forum Intex-type Pool Setup & Operations
    Last Post: 07-10-2012, 10:15 PM
  4. Intex Ultra Frame Pool Hard Plumbing
    By labmom56 in forum Intex-type Pool Setup & Operations
    Last Post: 05-08-2012, 01:34 AM
