Results 1 to 10 of 14
Thread: weight vs. volume
    Jun 2010
    new york
    Default weight vs. volume
    Silly question. If I'm supposed to add 1oz of cal-hypo is that ounce in weight or volume?
    Default Re: weight vs. volume
    It's usually sold by weight.
    If they want you to go by volume it's usually "1/4 cup".
    Jun 2010
    new york
    thanks. that makes sense.
    Lehigh Valley, PA
    1 oz dry weight is 1/8 cup or 2 tblsp.
    Here are some links to conversion charts:
    http://www.exploratorium.edu/cooking...surements.html
    http://www.foodgeeks.com/resources/conversion_charts#we see "Equivalents"
    You can also use Google to do the conversion. In the search bar type: 1 oz = ? cups or any other conversion.
    Quote Originally Posted by AnnaK View Post
    This is not always true. particularly with pool chemicals that have different densities. It is a rough approximation at best but if you want to convert a weight measure to a volume measure you will need to do it separately for each item, based on it's density.
    A pound of DE powder takes up a lot more space than a pound of trichlor tabs.
    For example 1 tablespoon of steel ball bearings and 1 tablespoon of rice krispies each would weigh 1/2 oz by the formula above but we don't even need to measure and then weigh them to know this is not going to be true!
    There is no hard and fast rule that will successfully convert a volume measurement to a weight measurement or vice versa.
    However, an inexpensive kitchen or diet scale is excellent for weighing out pool chemicals.
    Examples of densities of some pool chemicals are in this thread where the second number (bulk) is the relevant one. You can see that densities vary from 0.837 for calcium chloride dihydrate to 1.44 for dry acid. The one ounce weight to one ounce (1/8th cup) volume approximation is only correct when the density is 0.959 g/ml.
    Sorry for the bad formatting...the "CODE" formatting on this forum no longer works (that's used to force a fixed space font which is good for lining up columns).
    Lehigh Valley, PA
    Confused yet, purplegirl?
    sturev's Avatar
    sturev is offline Registered+ Thread Analyst sturev 0
    May 2010
    I wonder if the weights make a difference when she adds them to her green pool that's filled with iron? Gotta be heavier!
    Evan S.
    AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
    Jun 2010
    new york
    Post Re: weight vs. volume
    sturev are you making fun of my green pool
    I would probably be confused AnnaK if I didn't have a scale, but since I do I'm not going to worry about all the rest, I'll just weigh everything out.
    But thanks to everyone for the info. I never realized having a pool was so much work
    Your pool won't always be so much work. Once you have done this for awhile, it will become routine and will be easy. I typically spend less than 5 minutes each day on my pool. That is it. (Other than throwing in the Wanda the Whale vacuum a couple of times per week. But, then she does the work, not me!)
  1. Ever test the weight of your chemical containers?
    By famousdavis in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-29-2011, 12:59 AM
  2. Solar covers - 12 Mil vs 16 mil - weight an issue?
    By deckview in forum Pool Equipment & Operations
    Last Post: 06-06-2011, 04:55 PM
  3. weight of baking soda
    By ekaifes in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-09-2008, 01:31 PM
  4. Pool Volume
    By isdsms in forum In-Ground Pool Construction and Repair
    Last Post: 09-17-2007, 01:23 PM
  5. h2o volume of my pool?
    By dhale63 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-11-2006, 01:56 PM
