Results 1 to 9 of 9
Thread: Testing a SWG Pool
    Default Testing a SWG Pool
    I just installed an Intex 6453gal above ground pool with an SWG. It came with all the lousy test strips. I know I need a good drop test kit but am curious what levels I need to be looking for, and are all test kits created for salt and chlorine pools? I owed an inground pool several years ago so I'm some what knowledgeable as to what I'm doing. *I used poolforum.com as my bible back then!* I'm heading up to Leslie's soon and what to be well informed as not to be "pool stored!" Thanks guys!
    Default Re: Testing a SWG Pool
    Quote Originally Posted by dustybecca View Post
    http://www.poolforum.com/pf2/showthread.php?t=9664
    Scroll to the end and read my post.
    Ok got my test kit, muriatic acid, and some stabilizer. From what my manuals state it takes my pool 4 hours to cycle the water. I've been adding 3 cups at a time of muriatic acid to lower the pH to 7.2, in 2 days the TA has only come down from 250 to 200. If I let the pH rise back up so does the TA. What am I doing wrong? Also I haven't added any CYA yet, I'm at 30 there and even though I have the SWG I can't keep any chlorine in the pool. I've been adding 3 cups of bleach a day to bring the FC to 1.5 but by the end of the day *with no swimmers* it's back to 0. I'm running my pump and SWG at the minimum 8 hours a day. Here are all of my readings
    FC 0
    pH 7.2
    TA 200
    TH 100
    CYA 30
    If you are not adding anything to raise the pH up but letting it occur naturally then the TA is not rising any appreciable amount. The reason the pH is rising is that you are gassing off C02.
    Let me start at the beginning:
    1) your pool is carbonated like a bottle of soda. The carbonation comes from the bicarbonates in the water. We call these bicarbonates TA and we do want some because they act as a pH buffer.
    However if there is too high a concentration the tendency is for the pH to settle around 8.0 which is higher than we want.
    2) by adding acid we convert some of the bicarbonates to carbon dioxide (pour vinegar on baking soda to see this happen!). We have just lowered the TA since TA is only the bicarbonate (and carbonate) part of the buffer.The other part is the carbon dioxide but this does not count as TA because carbon dioxide in water is an acid and not an alkali.(At normal pool pH most of the TA is in bicarbonate form but as pH goes higher some does convert to carbonate form.)
    3) Carbon Dioxide in water is carbonic acid. This is the fizz in your soda!
    Shake up the soda and it goes flat because we have outgassed the carbon dioxide. The pH has also gone up because we have decreased the amount of carbonic ACID (CO2 dissolved in water) that is present. Operative word here is acid.
    So how do you shake up a pool? Aerate the water any way you can. Carbon dioxide will gas off without agitation but it takes a very long time. Aeration is just a way to speed it up. (If you leave a bottle of soda uncapped it will go flat in time but if you shake it you will cause it to go flat much quicker.
    SO...When you add the acid and drop the pH you have lowered the TA. Period.
    When you wait for the pH to rise naturally or put your finger on top of the pool and shake it up!...er, I mean aerate the water in some way to speed the process up you raise the pH with no impact on TA.
    Hope this is understandable.
    FC 0
    pH 7.2
    TA 200
    TH 100
    CYA 30
    What is your salt level? If the salt is where it is supposed to be I would bump up the CYA to 50 and see if it helps. If not I suspect that your unit is not functioning properly.
    Ok so I just need to stay on top of the pH and keep it low, and continue to aerate to "bubble off" the TA. I'm working on trying to find a salt test kit. I'll post those shortly.
    The AquaChek salt test strips are generally easy to find and are not that bad. I tend to use them a lot (and I also have a salt meter and a titration test for salt.)
    I have found them to be within acceptable range of the other testing methods.
    However, the are sensitive to humidity so keep them dry. I store mine in an air conditioned house.
    Salt is at 2930 ppm. I've been running the SWG almost 16 hours a day and it still won't keep FC up.
    Apparently, SWCG's are sized with the assumption that you'll have 60+ ppm of CYA in your pool.
    Get some dichlor (sodium dichloroisocyanurate) -- almost all the quick dissolve shock at places like Walmart is this stuff -- and use IT to get your chlorine up, and keep it up UNTIL your CYA is more than 60.
    Then see if your SWCG will maintain.
    PoolDoc.
    May 2010
    O.K. I just have to ask some very simple and basic questions. When I first got my SWCG it was loaded with features and display readings that I didn't understand at first. The owner's pamplet was no real help and I had to call the company to get instructions on how to set the unit up.
    So are you sure the SWCG is actually running?
    Mine has an Internal timer that can be set to any time of the day or night and also has the ability for the internal timer to be completely shut off and controlled by an external timer. If you look at your display does it give an output percentage? Mine can be adjusted in 10% increments from 10% - 100%
    What is your set at?
    If your pump is running, but the display says "IDLE" or "OFF" the SWCG is not producing chlorine. If my pump is running outside of the Internal time setting for the SWCG to be "ON", I get the "IDLE" message on the display.
    The Housing on my unit has a blue plastic where the cell is and you can see the water running through it, but more importantly you can see the bubbles forming on the cell telling you that the unit is generating chlorine.
    Can you see the water in your cell and the bubbles when the pump is running? No bubbles = no Chlorine.
    My SWCG has a SuperChlor button. When I push it, it turns the SWCG on its max output. Does your unit have this button? If so, what happens when you push this button?
  1. Pool store testing question
    By kevinm in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-21-2009, 06:05 PM
  2. testing pool light
    By rockg in forum Pool Equipment & Operations
    Last Post: 05-11-2009, 09:13 AM
  3. Pool Shop Testing, used for personal use?
    By KesLongwood in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-16-2006, 02:13 PM
  4. Should I be testing and adjusting even when pool is covered?
    By TfromNC in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-28-2006, 01:09 PM
