Results 1 to 8 of 8
Thread: Help with replacing pool light
    Long Valley, NJ, USA.
    Question Help with replacing pool light
    I think a kind of stupid question but will ask anyway.
    Need to replace the bulb on my Hayward Astrolite SP0580. It is 500W
    I took out the assembly and cord is long enough to work on deck.
    I took off the metal ring that attaches the plastic ring to the casing that houses the light.
    My quesiton is how do you take the lens off to get at the bulb?
    I didn't play with it much and put everything right back because we were having guests over, but in the 2-3 minutes I was playing with it, didn't seem like it would come out easy and there was nothing to grip so I can easily pull out. The rubber gasket seemed to be in there really good.
    Am I doing this right and just need a little patience or am I missing something simple?
    thanks!
    20x40 - 30K gallons inground vinyl
    Cool Re: Help with replacing pool light
    Al, GENTLY use a flat-head screwdriver to break the seal (be careful not to damage the gasket!) Some PBs say that you have to replace the gasket when you change the bulb - but I disagree! Perhaps a little silicone or Teflon based lube is in order but, unless the gasket is wrecked, just reuse it
    If you need more help on this - I'm here almost every day
    May 2010
    Default Re: Help with replacing pool light
    I don't know about the Hayward's, but the American Products (now Pentair) light lens gasket get's wrecked just by being clamped together for extended periods of time. I've not tried to lube or silicone seal (easier to just slip a new gasket on), mainly because i'm thinking about the poor slob (me), that would have to come in after to deal with the mess . With a new gasket, i'm confident that it won't leak(at least through the lens), and have to come back. They aren't that expensive to begin with, so i think it's money well spent. Perhaps the Hayward's are different.
    4 out of 3 people have trouble with fractions.
    Factory Warranty/Service for: Jandy, Pentair, Sta-Rite, Raypak, Polaris, and Paramount pool cleaning systems.
    May 2010
    Asheboro, NC
    Lightbulb Re: Help with replacing pool light
    I have done some experimenting with pool lights and have found that the uber expensive and fragile 500 watt bulbs can be replaced with a heavy duty 100 watt flood light with only half the loss in pool illumination at 20% less cost to run.
    Your mileage may vary.
    I got it!
    Sealed it back up nice and snug and after 3 days....no water in the light.
    Thanks for all the help!
    VERY much appreciated....just saved me a $90 service call.
    Searcher...your math is wrong.
    the $ in electrical savings 500% less the cost
    you are spending 5 times less when going from 500 watt to 100 watt.
    its all good ! ;-)
    May 2010
    Asheboro, NC
    Quote Originally Posted by albertgarrido View Post
    its all good ! ;-)
    Now why did I write "at 20% less cost to run" when it is 80% less?
    Brain fog, too late at night, old age?
    Pick excuse.
    May 2010
    I got it!
    A test you should try is to run the light for a couple of hours, let it heat up, then turn it off and let it cool.
    When you turn the light on, the inside of the fixture begins to heat up. Along with the heat, comes pressure. If the seal is not good, air will begin to escape. Then when the light is then turned off, the fixture cools and the pressure subsides, and you start to develop vacuum. This is when the light fixture begins to draw water into itself.
  1. CFL Pool Light Conversion & can't seal American Products Pool Light
    By DrBAF in forum Pool Equipment & Operations
    Last Post: 09-11-2012, 11:09 PM
  2. Replacing Fiber Optic Light with LED - Which One?
    By ImpetuousRacer in forum Pool Equipment & Operations
    Last Post: 05-04-2012, 12:02 AM
  3. Replacing a Spa light with an LED?
    By MashMaster in forum Pool Equipment & Operations
    Last Post: 04-10-2012, 07:32 PM
  4. Replacing 500w Pool Light
    By joelq in forum Pool Equipment & Operations
    Last Post: 06-02-2009, 05:53 PM
  5. Replacing Old Light Assembly
    By dbeaty2 in forum Pool Equipment & Operations
    Last Post: 08-21-2006, 11:47 PM
