Results 1 to 10 of 15
Thread: using citric acid to remove metal stains...
    SF Bay Area, CA
    Default Re: using citric acid to remove metal stains...
    OOPS! So sorry - the pH INCREASES when I add water. I'm not crazy, just goofed.
    I'll run full tests tonight to see where everything is. I have not had any problems keeping the Cl level up all summer, and (knock on wood!) haven't had any algae problems either. I expect TA will be on the high side because in the past I've had to run the spa with bubbles to bring it down - that is the one that needs aeration to lower, correct? I'm a little fuzzy on details because things have been running smoothly with pool for a couple of years and I forgot some of what I learned here before.
    In addition to putting the puck in the skimmer last night (and leaving the SWG running as usual), I also added about a quart of liquid Chlorine to bump it up. We'll see how much effect it had when I get home from work.
    Waterbear: dumb question for you - does the water always circulate through the heater even when not in use? At least in a standard setup? I imagine different pools could be plumbed differently. I'm not sure so I'll have to look at mine, but I had assumed (yikes) that it was bypassed when not used.
    In answer to your question - the spots were orange. I'll look into the CH (Calcium hardness, right?) to prevent new problems from cropping up though. I know the city water here doesn't typically have a lot of mineral content. If I need to increase it, how is that done?
    about 27,000 gal IG w/spa
    Polaris cleaner
    Autopilot SWCG
    Pentair cartridge filter
    Quote Originally Posted by river-wear View Post
    OOPS!
    Yes, normally, unless you have a bypass plumbed in and you turn the valves to bypass the heater. This is the exception rather than the rule since heater damage can occur if fired up with no water flowing through it.
    That would be iron
    Hope this helps
    SF Bay Area, CA
    I figured it was iron, but for the sake of curiosity, what color are copper stains? Green?
    Here are the full test results for today:
    Cl - zero again; added 1/2 gallon of 10% chlorine (sodium hypochlorite)
    pH - 7.2
    alk - 60
    Cal - 220
    CYA - 50
    salt - 2800ppm per test kit (AutoPilot says 3600...)
    What are the desired levels for alkalinity and calcium?
    There's still a puck in the skimmer and the chlorine generator is doing its thing, so I didn't want to add too much more of the liquid. I'll check on it again tomorrow. The water is clear and blue, but it feels like I'm tempting fate by writing that.
    I still have a few stubborn stains in one spot, but all of the little speckles have disappeared now. Is there something you'd recommend for spot-treating?
    Thanks!
    Polaris cleaner
    Autopilot SWCG
    Missouri
    I have a Hayward CZ 250 heater and it has a flow/pressure switch which detects water flow. If I do not have water flowing through my heater, the heater will not ignite. I also put in two valves that control water flow to the heater and also used to bypass it. This is a good idea in the Spring as water usually needs to be balanced and has crud in the flow. Also, during the summer months, when you do not need the heater, there is no reason to have water running through your heater. Doing so just exposes the heat exchanger to possible damage if you run unbalance water through the heater for an extended period of time. The damage is usually due to the copper in this unit. Trust me. I have already replaced one heat exchanger and it was expensive. Two cheap valves can eliminate most of the risk.
    Green, blue, black, grey, brown (copper color). Black and grey are the most common colors on fiberglass.
    pH - 7.2 bring this up to 7.6 slowly once your stain treatment is finsihed and all stains are gone
    alk - 60 bring it up to 70 ppm
    Cal - 220 bring this up to 400
    CYA - 50 bring this up to 80
    salt - 2800ppm per test kit (AutoPilot says 3600...) What kind of test? I would tend to trust the Autopilot on this since that is what the cell is actually measuring. It's still withing the operational range so nothing to lose sleep over.
    Put some vitamin c tablets in an old white sock and hold them on the stains.
    Thanks!
    Hope this is helpful. The numbers I gave you above will have your water 'balanced' even if the pH drifts up to 8.0, which happens with SWGs so you should not have any bad scaling conditions. It is a bit aggressive at a pH of 7.2 but you want aggressive water when dealing with stains. At pH of 7.6 to 8.0 you are golden and that is where I would recommend you run the pool. Don't let the pH rise above 8.0 nor drop below 7.6 in normal operation and you will be golden.
    SF Bay Area, CA
    Thanks for the help, Evan. I'll doctor things up to get a better balance. Maybe I won't have to be adding acid quite as often if the water is buffered better. I do usually run the pool at a pH of 7.6. One question though - why so high on the CH?
    You asked about the salt - I used one of PoolDoc's test kits for that. I think it's more accurate because when I was relying on the Autopilot last year (too lazy to test), the chlorine just didn't seem to keep up with demand and I had to put the SWCG on the highest power setting. Now, with the higher salt level I put it back down to the "normal" power setting (there are three) and the water has been clean & clear all summer. In any case, it's in operating range as you pointed out; it just seems to run better/more efficiently now. I also read that the Autopilot will read the salt levels with varying accuracy depending on the temperature of the water.
    Polaris cleaner
    Autopilot SWCG
    To keep the water balanced with the other parameters I gave you since you have a plaster/fiberglass pool. I kept your Saturation Index within 'range' with a pH range up to 8.0 so you don't develop scaling conditions and there is some evidence higher CH can help prevent fiberglass staining. The parameters I gave you for CYA, pH and TA are to minimize your acid demand.
    I am going to assume this includes all tests including pH and CYA, correct?), the chlorine just didn't seem to keep up with demand (sounds like low CYA) and I had to put the SWCG on the highest power setting. Now, with the higher salt level I put it back down to the "normal" power setting (there are three) and the water has been clean & clear all summer.
    Did you raise your CYA?
    Understand that the Autopilot is meaureing conductivity and not chloride ions like a chemical test. While the two are usually in the ball park they are not the same and for the sake of a SWG operation it's interested in the conductivity of the water and nothing more.
    (Poolsean, Please correct me if I am wrong on any of this)
    As far as the PoolPilot power settings, these should have nothing to do with salt level UNLESS you are running your salt way too low or unless your cell is fouled with calcium deposits and needs cleaning and cannot generate enough chlorine. The salt sensor in the AutoPilot is temperature corrected, which is why your cell output seems to fluctuate somewhat with temperature. My question for you was where was your CYA when you had to run at the higher power level? Low CYA is more likely to cause needed to bump the power than any other reason. Evan now at 50 ppm your CYA is too low and you should raise it to 80 ppm. This will translate into lower output setting which will translate into less CO2 outgassing which translates into more stable pH. The lower TA is also to lessen the outgassing of CO2. Ditto for not allowing the pH below 7.6 in normal operation. The lower you put the pH the faster you outgas CO2 and the faster pH rises.
    SF Bay Area, CA
    Interesting stuff, thank you!
    Today I picked up the baking soda for raising TA, and will get the CYA and calcium tomorrow.
    No, I wasn't too lazy to test other things last year. I just skipped the salt test. Last year I ran the Autopilot with it reading 2800-3000ppm (now it's 20% higher).
    My CYA is about the same as it was last year. I added some this spring because the pool overflowed with a bit with the winter rains, diluting it. That's why I had to add quite a lot of salt too. In any case, I will bring it up to the recommended levels.
    Polaris cleaner
    Autopilot SWCG
