Results 1 to 10 of 11
Thread: Help locating a replacement T15 cell still under warrantee.
    Largo, Florida
    Default Re: Help locating a replacement T15 cell still under warrantee.
    I don't know exactly where but I've been pricing cells as well. My local pool store only wants $500 for the T15, but I've found them online as low as $300. I was going to post asking about the site selling for 300 to see if it was legit but I think that sort of thing is against the TOC of poolforum.
    Quote Originally Posted by kelemvor View Post
    I don't see a problem with posting a question about the site to see if others have had experiences with them...the problem we have is with those who post links to their own site to entice people to shop from them, or with people asking for specific names of people to hire as contractors, etc. Basically, no selling here....but asking about an independent site to verify legitimacy would be okay.
    Keep in mind that any links you post will delay your post being modded in until Ben looks at it, so you might want to just name the site without the link...
    Your pool store is ripping you off!
    The retail price of a new cell with the 3 year warranty is not that high! Find a different store! For $980 you can but a complete Aquarite with T-15 cell and 3 year warranty!
    mas985's Avatar
    Pleasanton, CA
    Nearly every place on the web is selling them for less than $475.
    Try This.
    Forgot to mention the generics are now going for less than $400 with a 3-year warranty.
    Mark
    I am in Florida also and keep my pool heated to 88 degrees and it's over that for several months a year. The pool is open year round. I have an aqualogic and my cell is still going strong so the heat is not the problem, water balance is.
    A few tips to maximize cell life, keep your CYA at 80 (very important) an and your TA at 70 to minimize acid demand cause by outgassing of CO2.
    Add borates to 50 ppm to reduce acid demand (because of the secondary boric acid/borate buffer system that works in conjunction with the bicarbonate buffer system we call TA to "lock" the pH around 7.7 -7.8 for an extended peroid of time) and very probably chlorine demand (because of the algaestatic properties of borates).
    These tips will allow you to run at a lower output percentage and to minimize pH spikes, both of which translate into longer cell life.
    I was able to locate another dealer that offered me a better price (almost as good as online) but without the proration - you do what ya gotta do. I still had to pay the tax though.
    However, it's obvious to me that I am going to have to rebalance my pool. My pool is an inground with a Premix Marbletite Marquis finish and comes in at about 11000 to 12000 gals is my buest guess but a calculator says around 15K gal. Its an odd shaped pool. It is uncaged, and gets sun from 8:00 am to 7:00 pm right now. My current pool stats according to the pool store:
    Salt 4200
    CYA 120
    FC 1
    pH 7.8
    TA 105
    Calcium Hardness 260
    TDS 5001
    The pool store recommended that I put in two cups of acid to bring down the pH and 1 gal of liquid chlorine to up the FC level.
    My handy dandy PS234 #6477 test kit gives me the following readings:
    FC 1.5
    CC 0
    OTO TC 2
    OTO pH 7.5
    Alk 80
    Cal 300
    Cya 70
    Salt 3800 ~ 4000
    Meanwhile, my new and improved (working) cell allows me to get the following readings from the Aqua Rite control box:
    Salt 3200
    Temp 92 deg
    Volts 24.3
    Amps 7.70
    40% chlorine generation
    ~3800 (Instatenous salt test)
    AL 0
    r 1.40
    What is the next recommended step to do. Should I drain and refill to lower the salt level or should I leave it as it is because within one week, the overflow from all the rain will do the job of lowering the salt level for me?
    What is this borates thing? If you haven't guessed, I do not have much of a clue about this stuff....
    Thanks for your help.
    Quote Originally Posted by Nevets View Post
    Read Waterbear's post #2 in this thread....
    http://www.poolforum.com/pf2/showthread.php?t=10305
    Salt 4200
    CYA 120
    FC 1
    pH 7.8
    TA 105
    TDS 5001
    You need to subtract your salt reading of 4200 from this to get the remaining TDS, which is really not a very useful test. Your TDS is about 800 according to the store's tests, which I find suspect! TDS stands for Total Dissolved Solids which will be the salt, calcium, CYA, magnesium. potassium, bicarbonates, sulfates, etc that are in your water.
    I would ignore the store's tests and recommendations! Trust your own testing, assuming your reagents are fresh. If not I would order new FAS titrant, possibly new DPD powder, possibly pH reagent (it does go bad!) and, if you want to test salt chemically a Taylor K-1766 from Taylor Technologies, it has fewer problems than the salt test included in the PS234 even though they are basically the same. The difference is the concentration of the titrant for chloride.The test is tricky at best and because of static and non uniform drop size because of some static issues in the PS234 droppers it can often give a reading that is a bit higher than it is. As an alternative AquaChek salt test strips are a useful tool as long as they are fresh and have not been exposed to humidity. With any chemical test for chloride ions, reagent or strip, the results will not be the same as the conductivity reading from the cell but if they are within about 800 ppm you are certainly in the ballpark.
    FC 1.5
    Too low, keept it around 4-5 ppm at all times
    pH 7.5
    Fine for now but you don't want it to go any higher than 7.8. When it does drop it to 7.5 and not lower because the lower you put the pH the faster it rises.
    Alk 80
    OK but would be better at 70 ppm.
    Cal 300
    Should be just a bit higher to keep the water balanced for your plaster finish. I would bump it up to around 350 to 400 ppm given a TA of 70-80 ppm.
    Cya 70
    OK for now but if it drops any lower bump it back up to 80 ppm.
    Salt 3800 ~ 4000
    Salt 3200
    You want to go by instantaneous salt and not average salt readings so ignore this.
    Temp 92 deg
    Volts 24.3
    Amps 7.70
    This is your salt reading, It is also in line with the titration test you did. It is a bit high but livable. As we are going into rainy season here in Florida I would not lose any sleep over it!
    AL 0
    r 1.40
    Hope this helps.
