Re: High PH - Spa spillover raising PH in SW Pools?
also, how much sandstone is flaking off? is it dissolving in the pool, or mostly just chunks that get removed fairly quickly?
Sandstone can change ph, but only if dissolving- if whole chunks are in but removed before substantial dissolving, shouldn't make "much" difference...
I didn't use 2 gallons acid all last year, much less in a week!
