Keep in mind that you need 14 times the pipe diameter of straight pipe for the flow meter to remain accurate. Most pumps don't have that much pipe on the suction side. Also, on the suction side of the pump you have to deal with debris clogging the flow meter. I would recommend a pressure side install after the filter.
