Thread: Sand Filter Issues
    Jul 2011
    Wantagh
    Default Re: Sand Filter Issues
    I'm not sure but could it be you didn't wash the sand first? Did you backwash before you set it to filter on start up? how about your multiport is the o ring and the spider gasket in good shape?
    BigDave's Avatar
    I would make sure the borwn stuff (sand?) doesn't go through the solar loop.
    I have a 1/2 hp pump that's rated at 40GPM...your filter may be too small. Do you have a valve that you could use to throttle the flow?
    Jul 2011
    Gobles, MI
    Quote Originally Posted by not2high2fly View Post
    I backwashed the filter before using it, but I think that I should have possibly rinsed it longer before putting it into service. The sand flow has diminished to almost nothing after a couple of weeks. I believe that the o-ring and or the spider gasket could be bad because I have to fiddle with the lever every time I move it to stop it from leaking. The unit is quite old and I'm having trouble finding a clear replacement. I hate to tear it apart until I am sure I have the right parts.
    I do have a ball valve in the return line that I use to throttle the flow down some.
    Thanks for the responses guys!
    18' x 48" round Atlantic pool, 1hp pump, ATL140 90# sand filter rated at 20gal/minute, black-rubber-hose-on-the-roof solar heater.
  1. Issues with low or no pressure on DE filter
    By Jarrod in forum Pool Equipment & Operations
    Last Post: 07-08-2012, 10:19 PM
  2. Filter/vac issues...
    By skizz0tt in forum Pool Equipment & Operations
    Last Post: 08-29-2011, 01:41 PM
  3. DE Filter issues.....
    By fog80 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-07-2011, 03:43 PM
  4. Sand Filter Issues
    By djonesax in forum Pool Equipment & Operations
    Last Post: 07-31-2010, 09:15 AM
  5. Pressure issues Sand Filter
    By let_her_flicker in forum Pool Equipment & Operations
    Last Post: 05-28-2006, 11:58 AM
