Thread: Jandy LT400N-L Pool Heater Question
    Largo, Florida
    Default Re: Jandy LT400N-L Pool Heater Question
    I had a similar problem when I bought my house. Turned out that even though the tank in my yard was full of gas, the gas company had shut off one of the valves to "disconnect" the service when the previous owner left. Kinda was a shocker to me since I didn't think of gas in a tank on my property as a service... I figured I bought a house, and the big tank of gas came with it just like the water heater in the garage.... but anyway, are you sure you've got gas running to the heater?
    I hope shell never decides they are going to put a valve on my car's gas tank...
    Quote Originally Posted by kelemvor View Post
    I hope Shell never decides they are going to put a valve on my car's gas tank...
    Not Shell.
    But I think Al Gore is already working on it.
    Sep 2011
    I solved the problem. One end of the vacuum hose between the blower and the air pressure switch has rotted and fallen off. $2 of new hose fixed it.
  1. Dead heater, remote control, wiring jandy valves
    By jqgreen in forum Pool Equipment & Operations
    Last Post: 08-12-2012, 08:36 PM
  2. Thinking of buying a Jandy Legacy 250BTU EN heater
    By Robber71 in forum Pool Equipment & Operations
    Last Post: 05-11-2012, 03:26 PM
  3. Jandy LT Heater Help
    By rebytr in forum Pool Equipment & Operations
    Last Post: 03-05-2007, 09:09 PM
  4. Pool heater question
    By JeffB in forum In-Ground Pool Construction and Repair
    Last Post: 11-01-2006, 01:35 PM
  5. Jandy LX400 Heater help
    By cygnusecks in forum Pool Equipment & Operations
    Last Post: 05-18-2006, 01:44 PM
